DP cat or no cat
Old Jun 19, 2007 | 04:50 PM
SSalexSS's Avatar
DP cat or no cat
I was lookin into the ZZP Downpipe
wat do u think would b better for more power highfow cat or no cat?
i would figure highflow cat to create back pressure...but maybe im wrong
Old Jun 19, 2007 | 04:57 PM
XM15's Avatar
If all you are concerned about is peak power, go cat-less. But having a cat will make your exhaust sound much better as well as make your power curve much better. The reason I say this is because I was with another member when he put his car on the dyno after putting a cat back on. He lost a few peak horsepower, but the midrange was much better.
Old Jun 19, 2007 | 05:02 PM
SSalexSS's Avatar
i see so with cat is prolly better cuz u still get power out of it and u keep a nice tone
i have 2.5 exhuast so shoudl i jsut go with the 2.5 dp
Old Jun 19, 2007 | 05:05 PM
XM15's Avatar
The 2.5 dp would fit your setup perfectly. And yeah, I don't think you would like the sound of your exhaust without the cat; it would end up sounding very raspy.
Old Jun 19, 2007 | 05:12 PM
SSalexSS's Avatar
yea that how my exhaust sounded i had it custom made then when i reved it it was way to raspy..i reliezed my resonator wasnt in so i had them put one in much better nice low rumble
Old Jun 19, 2007 | 05:19 PM
Shortbus's Avatar
I would say if you are highly modded you might want to ditch the cat because i know on my car mine got way way too hot, most of the power coming from going catless is in the tune, because you cna bump up timing, more timing = more power.
Old Jun 19, 2007 | 05:22 PM
SSalexSS's Avatar
im not highly modded lol i dont even have stage 2 im trying to find a good deal on it but never can
Old Jun 19, 2007 | 05:23 PM
Psykostevo's Avatar
I had to get rid of the CAT to get rid of excessive heat. By getting rid of it I was able to add timing and as a result I gained more power all over.
The big downsides are louder exhaust, raspy exhaust note, and smell. The worst part of this is the rasp.
Old Jun 19, 2007 | 05:26 PM
Shortbus's Avatar
Well if your not highly moded and dont plan to be, or plan to have stage 2 then go with a cat.
Onyxd04Redline's Avatar
How strict are your emissions?
Old Jun 19, 2007 | 05:30 PM
Psykostevo's Avatar
Hey I see you are in Tempe. I don't think we have met. Do you have the Black RL with the gauge cluster on the pillar?
Old Jun 19, 2007 | 05:32 PM
Will be in tempe in a few days.
Old Jun 19, 2007 | 05:34 PM
CobaltSS313's Avatar
Yah due to high heat problems i got rid of my cat, no cats FTMFW!!
Old Jun 19, 2007 | 05:35 PM
As for the heat problem. I do plan on going with a 3" O/R DP when i go with my ZZP header.
Old Jun 19, 2007 | 05:38 PM
SSalexSS's Avatar
do u think alc inject would help lower the heat or no or if u get coolin mods....
or does that not have nethin to do with exhuast
Old Jun 19, 2007 | 06:45 PM
Psykostevo's Avatar
Exhaust is heat created after the burn. Alcohol does not help there. The idea is to get the HEAT away from the cylinder head as fast as possible.
Old Jun 19, 2007 | 06:48 PM
SSalexSS's Avatar
mmm i c thx
Old Jun 19, 2007 | 08:28 PM
Maxim_X's Avatar
Catless changes the exhaust tone more than you can imagine. My car with the dump open sounds like a Honda now. But, when I look at my stock dp it is easy to see that it was glowing red hot before.
Old Jun 19, 2007 | 08:31 PM
SSalexSS's Avatar
wat gains do u see usualy w/ the dp n wats the best dp 2 get
Old Jun 19, 2007 | 10:24 PM
BCobaltSS's Avatar
What would be better for a DP 2.5 ZZP or CA and hi flow cats on both . Or just keep stock
Old Jun 19, 2007 | 11:57 PM
Shortbus's Avatar
I wouldnt say anyone d/p is better than the other, anything dp is better than the stock one, you will see higher gains without a cat, due to you being able to bump timing via hp tuners, but you should see a descent gain with a 2.5 d/p with high flow cat.
Jan 12, 2016 12:01 AM
nathan112i
Sep 30, 2015 07:12 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
