driving Boom Boom Boom Stall
me and my buddy were on the interstate tonight and around 120 mph and 6500 rpm roughly the car went boom a big flame shot out of the exhaust then the car stalled i tapped the gas and all you could here was supercharger so i pull off the side of the road and wait a few minutes and start the car again and it is running fine i didnt do any hard pulls but i did hit full boost does anyone have any idea what happened? did i detonate? maybe a bad plug/coilpack? a little bit of info would be great thanks
Have you looked in the motor, checked your plugs? If its running fine, then I would *think* that there isnt permanent damage, although a big flame out the back is kind of :wtf:
Check your plugs, see if they have anything on them they arent supposed to. My guess is that your cat will be fried, and maybe some o2 sensors as well at the very least. |
Originally Posted by Johnboy12358
(Post 3899948)
did you look at plugs?
Why were you going that fast on the interestate anyway dude.. fucken stupid.. Serves you right for doing that. But Good fortune on your sit-e-ation =]
Originally Posted by SedanMan08
(Post 3902678)
(Post 3902674)
your oil smelled of gas???
i think the sound you heard is probably self explanitory.. going boom boom boom is never good lol
Originally Posted by elecblue06
(Post 3902749)
im guessing...sometihing really bad lol, like maybe rings blow???? hole in piston??? something as such |
Originally Posted by NWAE Cobalt
(Post 3902760)
QFT
i would start by doing a compression test, that shows ok then you have compression in the cyl which should mean you have good valve seel and such, if it is still compressing just not enough do a wet compression to see if its the rings...if that fixes it then piston ring problem. if that doesnt fix it then would start by pulling the valve cover, check the tops of the valves, then pull the intake mani and check what you can see through the ports, same witht he exhaust. if all seems goodincluding supercharger then pull the head...
thats how i would proceed.. and good luck, keep us updated |
another one bites the dust...
(Post 3902823)
aaaand....yer done.
do a compression test, starting with #4. I'm guessing the exhaust note sounds something like a WRX |
at first i was thinking you blew out your cat bc that happend to me a while back i was doing a 2nd gear pull and it made loud bang and stalled and threw alot of black smoke. i checked under the hood and all was normal, it started and ran fine i threw an 02 sensore code a week later and well my cat was gone haha.
that was a year ago and shes still running fine, your problem seems alot more serious goodluck getting it fixed |
Originally Posted by Bika
(Post 3903360)
aaaand....yer done.
let us know if you need any help with anythign also...ive had to do most of these tests recently when i miss timed the car and bent all my exhaust valves :(
Blown ringland
update
compression test turned out normal so thats good news went and bought new plugs 1 step cooler gapped them to .035 still didnt fix the problem so i decided to take the d/p off and when i did this huge ceramic/metal metal hunk of cat fell out so needless to say it was the cat all along .... so i pounded out the cat with a huge bar and blew it out with the compressor and i think she is gonna be just fine........for now....... thanks everyone for your help |
there you go ;)
good job!!!!!! |
(Post 3904484)
there you go ;)
good job!!!!!! |
Just as an fyi your going to toss a cel, it will be p0420. Whoever did your tuning can block it from popping on.
edit: Also something to consider buying later on down the road would be an egt gauge and or an interceptor. |
(Post 3899948)
Check your plugs, see if they have anything on them they arent supposed to. My guess is that your cat will be fried, and maybe some o2 sensors as well at the very least. Glad you found the problem, time to upgrade that downpipe! |
i think they 120mph at 6500rpm might have done it...
Originally Posted by Zach06CobaltSC
(Post 3904638)
Originally Posted by afireinside7710
(Post 3904910)
| All times are GMT -4. The time now is 02:09 AM. |
