dual pass
air can/will get stuck in the top of the endplate and its a pain in the ass to get it out. hold up the top hose on the endplate over your head while the pump is on to get it out
How are your hoses routed? Pic of the setup will help. Probably have something setup so it's trapping an air bubble. That little pump can only do so much, and it won't push air out of a loop in the hose aparrently.
ill get a pic when i get off work at 10 but i think its air bound, whats the best way to bleed it i have a cx fmhe plumbed into the stock with a stu mod
ya i believe my cores are right small holes fluid in big holes fluid out,
i was thinking about making a hose to put on "in" side of the pump and submegging it in coolant, also if my core were wrong would i still get flow?
ok so i primed the pump and it went through the end plate out to my coolant tank and now it wont go through the stock h/e, when i turn the pump on my coolant tank over flows, any other options besides removing the bleeder screw because its in there good and its starting to strip.
thanks
thanks
never gave me a problem until i did dual pass and before that i did 2 res. swaps and an aftermarket h/e
bump for help
bump for help
This as well. If you do this, it bleeds constantly. As long as you have your hose setup correct, so it's not trapping air in the manifold or something, you are good to go.
my hoses are set up correct, but it refuses to go through the the stock h/e, i gotta take the grille out and take out the stripped bleeder screw
my hoses go, pump to endplate, to tank, to stock h/e, to aftermarket, and then back to the pump
z28addiction
Sep 28, 2015 12:03 AM
