Dual Pass End Plate
Old Jan 23, 2007 | 04:10 PM
Gonzo2007's Avatar
Dual Pass End Plate
I have a hard time understanding what this plate does...do you need to buy anythign else? if you buy it form gm is it all you need?
Old Jan 23, 2007 | 04:41 PM
Bostitch's Avatar
i Agree. can anyone elaborate for us. or maybe some pics of the before and after setup
Old Jan 23, 2007 | 05:20 PM
Blown 4-banger's Avatar
Click on the link in my sig that says "Dual Pass IC Mod"
That should clear some stuff up for ya
Old Jan 23, 2007 | 06:46 PM
BlilBT's Avatar
I just got Mine in the mail, My New Dual pass Heat exchanger got here yesterday! Now waiting on my Custom made Billet Overflow Bottle <<From BWoody! I should be seeing some very cool Numbers & For down here in Florida its always Hot! It should Help alot! Im logging all the #'s Now with HP Tuners & going to Log the #'s after!
Old Jan 23, 2007 | 07:55 PM
pierre's Avatar
If I might make a suggestion.
Get a logs of simulated 1/4 mile runs if you have a safe place to do it. Something like 5-95 MPH at full throttle would be usefull information. Don't forget to bleed the air out of the stock HE so it's a fair comparison.
It would also be usefull to do the endplate mod, get data then ad the aftermarket HE so as to be able to evaluate each change independantly.
Good luck
Old Jan 23, 2007 | 08:05 PM
BlilBT's Avatar
Good luck
Already Logged all the above, The Problem with doing each 1! It will envolve To much time! I'm Doing the End plate & exspansion Bottle at the same time Because of Plumbing change. (Option B) of Endplate Install!
Old Jan 23, 2007 | 08:18 PM
JapEatr's Avatar
South Central *********
not expansion bottle but, Heat Exchanger such as the cobra one or the cobalt addiction HE
i just got the GM endplate, the GM surge tank, cap, and y fitting, intake gasket(updated for more boost)
THanks CED!
also i plan on running dual pass option B, with an additional cobra heat exchanger, with the stock HE as well
waiting for more parts before i install
Old Jan 23, 2007 | 08:19 PM
pierre's Avatar
I consider the expansion tank to be a required addition. It would be very hard to get the air out with option 1.
What do you have data logs of so far?
Pierre
Old Jan 23, 2007 | 09:14 PM
97 Z Me Go's Avatar
With the expansion tank (the one from the redline) you just run the over flow hose to the fitting on top of the stock heat exchnger correct?
kyle
Old Jan 23, 2007 | 09:17 PM
BlilBT's Avatar
kyle
The 1/4 inch Outlet is the Bleeder Line, For the Bleeder Valve you have to install!
Old Jan 23, 2007 | 09:23 PM
pierre's Avatar
kyle
Not the overflow hose. There is a small fitting near the top, 1/4" hose I believe, that gets plumbed to the fitting on top of the exchanger using the .040" orfice.
Pierre
Old Jan 23, 2007 | 09:28 PM
BlilBT's Avatar
Pierre
^^^Yea there is a 1/4 Plug in the Stocker!
Old Jan 23, 2007 | 09:53 PM
Rage915's Avatar
if your going with the GM one theres two options A and B, B requires an additional surge tank y fitting and cross lines
Old Jan 23, 2007 | 10:13 PM
97 Z Me Go's Avatar
Correct me if im wrong. Maybe im missunder standing. But on the extra coolant bottle. Theres a 1/4 inch hose running off. Gm says make some goofy bleeder set up. Cant you just take that 1/4 line and run it to the top of the heat exchanger where there is a fitting there that gm just put a plug in? its the highest point in the heat exchanger and the highest point in the coolant bottle. That should mean it bleeds all the air out?
Old Jan 23, 2007 | 10:25 PM
BlackSS/SC's Avatar
I just finished doing option B last weekend. You are correct, the 1/4 air bleed line goes from the top of stock heat exchanger on the passenger side where the pipe plug is, over to the top of the stock Redline coolant tank's 1/4 nipple. HAHA, I said nipple. The reason the .040" orfice is there is to restrict flow back through the 1/4" line.
Old Jan 23, 2007 | 10:50 PM
Johnboy12358's Avatar
haha, you said orifice....
Old Jan 24, 2007 | 01:07 AM
squeak's Avatar
are you supposed to bleed air from the stock exchanger as a regular maintenance or is there a stock coolant for it that you have fill? im lost when it comes to heat exchanger thing? what im trying ask, is there any kind od regular maintenance that needs to be done concerning the stock heat exchanger at all?
Old Jan 24, 2007 | 12:08 PM
BlackSS/SC's Avatar
No normal maintenance required, the bleed line automaticly bleeds air out of it. You may just have to top up the coolant resivoir time to time at first.
Old Jan 24, 2007 | 12:50 PM
I just had to top up. Stage 2 install makes the coolant level drop a little. No big deal.
Old Jan 25, 2007 | 08:48 PM
spaz's Avatar
OK so we flip the bottom two laminova tubes around and feed the coolant from the pump into the centre and the oulets top and bottom get teed?? just getting the fitting welded on and going to do this mod when I get it back. This is what it looks like to me but I don't have the instructions.
Old Jan 25, 2007 | 10:11 PM
Rage915's Avatar
question is this mod worth it or a second HE is enough i want to get both but don want to spend money if i dont have to.
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
