Dual Pass Install
Dual Pass Install
I will be installing my dual pass tommorow,anybody have any advice that will make it easier?Thanks
balts have to take the IC pump off anyways..
just take your time and make sure you get everything nice and tight.
and get an adel clamp to get the laminovas out, severely do not suggest a pair of pliers or anything like that.
plenty of info on how to do it
Last edited by daythecountrydied21; Jul 8, 2009 at 07:51 AM. Reason: Automerged Doublepost
he did his own you don't want to follow that if it's the one im thinking of.
not GM dual pass.
if you get stuck or anything during it feel free to PM me.
hardest part is the hosing and that's just more annoying than hard.
not GM dual pass.
you do not have to take the i/c pump off.. I took the alternator out and moved it aside to get the bottom bolt. and all you need is one of the screw type hose clamps to get the laminova's out..
Take your time and make sure everything is in correctly.
I have all the hoses ran already as i am running the option b tank right now.I have it set up so that after i install the dual pass endplate,all i have to do is add the other t-fitting and run one more hose.
Ok guys i have the s/c and intercooler pump off,my question is which to bolts do i take off,the 2 closest to the bottom of the manifold or the 2 closest to the pump?
You are correct. Only one holds the very bottom on under the mani that you can't really see. I just did mine last week. It's really preety easy.
yeah one bolt on the bottom, it's not necessary to put it back, i did just for ***** and giggles.
then theres 2 things holding the im into the head, you need an e-torx socket but if u don't have that just make sure you uninstall and reinstall those 2 SLOWLY. the others should be self explanatory.
theres also one by the dipstick i think, u need to disconnect the dipstick from SOMETHING i forget what, unsure if that's just the ions or both of us
I haven't done it myself so I dont have any useful hints, but you should check this out:
http://northernstardesigns.com/artic...odsInstall.pdf
