Dual Pass + Opt B
Dual Pass + Opt B
Ok, I know I've posted some threads on this but here is the thing. My dealership wants to charg me 312 dollars installation which is 4 hours. I know that isn't that bad. But for 635 dollars....is the dual pass gonna be worth it. I mean thats rediculous.
So I was thinking of not using the dealership. Would you guys reccomend this? I want the work to be warrantied (my car isn't under warranty anymore). But I am scared joe blow ina shop will mess something up. Is this a risky install????
I'm terrible with tools. Like beyond your belief. I'm always scared to screw something up. I would actually use the term Chicken ****. But I have no experience at all. my buddy that normally helps me out and has a garage with every tool under the sun is copping out. I've always just paid him like 50 bucks to give me a hand for a few hours. He has a gagage with all the tools under the sun. Plus he has a very reliable turbocharged integra...so he has aftermarket experience.
Anybody within two hours of southeast alabama wanna install my exchanger and dual pass for 100 bucks?? lol
Damn, took me about 6 hours but it wasn't that bad when you add a 18 pack and a good friend. Oh yea, we also had a lift but i could of done it without one.
Its not like I saw one and thought it looked cool...otherwise I would have rims by now with a drop, a drift spoiler, and some HIDS/projectors.
with 19 post I would think you would have chosen your words more carefully. I have a 2.9 pulley ona stage 2 tune. I know that cooling always helps. Not always "needed", but always helps.
Also running a 2.9 doesn't warrant any cooling mods regardless of what people tell you though go lower and you should as well as upgrade to 60's. Yeah 140 degrees is better than 150 degrees but it's not going to make your car "perform" any better (ie faster). Yeah if you reduce temp it will reduce wear on your engine but if you wanted a car that lasts 100k+ miles you wouldn't be doing any modifications and you'd be driving a honda.
It's your car, it's up to you. People have been running 2.8s on the canned stage 2 tune for over 20k miles without any cooling mods and aren't having any problems so...your choice.
Well if you can't do the install yourself for the dual pass then just install the other h/e because any monkey with a drill can do it and it shouldn't take more than an hour and a half to do. If you want to front at least 300 bucks to do a cooling mod that won't reduce your temperatures any more than simply installing the other h/e then go ahead, no one is going to do it for any less.
the local race shop has dyno proven that cooling mods can be the best bang for buck on these cars as it allows the ecu to give full power without retarding timing. get as much as you can afford.
As compared to a cold engine theres no power add, but after youve heatsoaked the hell out of the engine, its worth it. I have a 2.9 as well with a dual pass+B and cxr h/e. just my 2 cents.
Dual pass install is not for the newbie. expect lots of cursing, scraped up knuckles, more cursing, head scratching over hidden bolts, and ability to craft your own bracketry/hose routing.
z28addiction
Sep 28, 2015 12:03 AM
