Dual Pass plumbing help
Hey guys, so i have installed the S3 H/E and dual pass plate. I cant find for the life of me where to or how to add back in the filler neck for the plumbing. My whole S3 kit from ZZP came with Zero instructions. Please help, if anyone has a diagram with the filler neck in it would be super.
I have also seen this diagram plenty of times, there is no direction for where to put the stock filler neck. I dont have opt B tank.
Thanks Coby
Thanks Coby
i'm confused. Whats so different in your setup?? If all you have is dual pass and another heat exchanger you route it like this.
out of dual pass>stock filler neck>pump>stock heat exchanger> second heat exchanger>dual pass
Exactly what ssyellow said. Top and bottom prong of the dual pass into a T fitting, then to the filler neck. Other side of the neck goes to the side prong of the intercooler pump. As for the placement of the pump I kept it in the same spot.
z28addiction
Sep 28, 2015 12:03 AM
