Dual Pass STU
Old Dec 23, 2010 | 01:44 PM
LE5_AJ's Avatar
Dual Pass STU
Hi, i was just about to modify my friends cooling system that currently has dual pass, stock & zzp heat exchanger, and option b, but his IAT's are basically engine temp. most of the time. This can put me under the assumption that his pump is either out or on it's last leg and i know that with all of the stress from having both heat exchangers and how poorly everthing is ran that it needs to be redone well i'm getting rid of the Option B and going with the STU mod on this and taking the stock heat exchanger out. Here is how I was thinking of running it but i wanted to make sure i'm doing it correctly.
Old Dec 24, 2010 | 05:18 PM
damien's Avatar
Keep the stock IC unit. The ZZP is not large enough to run alone
Old Dec 25, 2010 | 07:22 PM
goeckeritz123's Avatar
Where can you get the tank
Old Dec 26, 2010 | 01:54 PM
06cobalt racer's Avatar
you replace the stock filler neck with the stu mod
Old Mar 18, 2011 | 01:17 AM
redcobalt07's Avatar
So if you just have an option B tank instead of that STU mod is that the correct diagram for running a dual pass setup?
Old Mar 18, 2011 | 01:48 AM
nizzle's Avatar
It's either the pump or air in the lines. The ic pump in our cars is the same ic pump that is in the ford lightening, svt cobra, and in the supercharged mercedes as well. ALL the guys who run ALL theses different cars with this same pump complain of the pump going out. I was having iat issues and found that mine was out too. I replaced it and iat's went WAY down. I would say pump is the issue. I have the stock HE with the zzp S3 HE, option b tank, dual pass plate, and the pump works just fine.
Jan 12, 2016 12:01 AM
cw383
Sep 30, 2015 12:41 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
