is this dumb?
Old Jan 8, 2009 | 11:58 AM
scott allen's Avatar
is this dumb?
i have a ss/sc,2.79 pulley,gm stage 2,injen cai,cx racing heatexchanger,gmpp catback. Do you all think it is running lean?Do you all think i should get 60 s and a tune,also next month i will be getting a header and catless dp.
Old Jan 8, 2009 | 11:59 AM
KillerBee's Avatar
You should have 60s for a pully smaller then 2.9 cause the 2.9 maxes out the 42s and you dont want pissed off injectors
Old Jan 8, 2009 | 12:05 PM
uthinkimodd's Avatar
I'm not going to get in to the injector arguement but I reccomend you get tunned see what the guy tunning your car tells you and go from there.
Old Jan 8, 2009 | 12:08 PM
lsjwannabe's Avatar
stage 2, with a 3.06" pulley on it.Now think whats happening with a 2.79" pulley.
Get the 60's and a tune trust me.
Old Jan 8, 2009 | 12:10 PM
PRND3L's Avatar
115 duty cycle, yeah, needs MOoooooooooRRRRRRRRRREE!!
Old Jan 8, 2009 | 12:12 PM
blackss2.0's Avatar
you need 60's. 42's are getting maxed out probably so ur def running lean.
rallycobalt06's Avatar
listen to this guy.......
also you can buy 60s from OTTP for a really good price.
Old Jan 8, 2009 | 12:15 PM
Psykostevo's Avatar
I've seen some cars run lean like crazy (13.9 AFR under WOT)with that size pulley. It's mostly the tune, not always the injectors fault. The GM tune shouldn't be used beyond their provided pulley.
Old Jan 8, 2009 | 12:17 PM
amen to that!
Old Jan 8, 2009 | 03:58 PM
When i get 60s and a tune how much power can i expect.
Old Jan 8, 2009 | 07:01 PM
jeanbalt's Avatar
60's don't change power but they prevent you car from running
lean ... which can lead to boooooooooom
especially in cold weather (being from canada I know)
your car will run leaner especially at start uo
Old Jan 8, 2009 | 07:05 PM
Yea, but it seems if it is running lean and you give it the fuel it needs you would pick up power
Old Jan 8, 2009 | 07:08 PM
DebadgedBALT77's Avatar
dont worry about pwer right now. get the 60's and focus on saving your engine. listen to LSJwannabe. after to get the 60's go get tuned and then worry about making power.
Old Jan 8, 2009 | 07:14 PM
jeanbalt's Avatar
you get more power when running lean but heat follows then boom follows
I use mine as a daily driver I don't want to blow my car up
things you need when tuning
wideband you need to know what your a/f ratio is
areoforce gauge -- knock IAT 2's you willing to blow up your car cause you didn't know
any better ?
go to HP tuners forum learn learn learn
then mod
the easy way is to go with a stage 2
Old Jan 9, 2009 | 12:29 AM
lsjwannabe's Avatar
Its hard to say what you would gain in terms of power, depends on how aggressive of a tune you went with. Things you are getting out of it is much lower injector duty cylce's so you can actually control the cars fueling above 5k rpms. Not to mention your setup is probably knocking up top.
Old Jan 9, 2009 | 11:01 AM
Psykostevo's Avatar
No doubt
any better ?
then mod
At the least take it to a dyno when tuning so that you can log AFRs. And IAT2s HAVE to be watched, and a lot of attention paid to them. They falsely drop when the bypass opens making people think the supercharger cooled down. Gotta learn what NOT to do!
Old Jan 9, 2009 | 12:58 PM
matego's Avatar
LSJ.... what else was done to that thing? Its pulling the same amount of air as my 2.9 pulley. I would like to know... I like flow
Old Jan 9, 2009 | 12:59 PM
lsjwannabe's Avatar
Thats stage 2 and a intake, the airflow can be skewed depending on how the maf is calibrated. Don't weigh to much on that
Old Jan 9, 2009 | 01:16 PM
matego's Avatar
Yeah, I figured. I thought you may have some super secret stuff you are brewing up down there. I just figured that scan was after the tune/maf calibration because it was cranking 21 deg timing. You have a PM coming your way
Old Jan 9, 2009 | 01:20 PM
lsjwannabe's Avatar
Thats a stage 2 timing map
Old Jan 9, 2009 | 01:27 PM
matego's Avatar
My car must be retarded (literally ) When I had the st2 tune I couldnt get that kind of timing. There is a ton of variables though that affect it with all the adders etc. I must have had more reducers than adders. HPT fixed all that though
Old Jan 9, 2009 | 01:32 PM
mcphatty's Avatar
why is your duty cycle so high? i'm running 2.9 with 42's and my duty cycles are only around 90 at WOT
Old Jan 9, 2009 | 01:35 PM
MBMCustoms's Avatar
a tune can do a lot of things ^
Old Jan 9, 2009 | 01:39 PM
lsjwannabe's Avatar
i believe the 07 stage 2 timing map is slightly higher than the previous
stage2 tune <custom tune
Old Jan 9, 2009 | 02:50 PM
Psykostevo's Avatar
Your MAF scaling will effect the air calculations that the Timing table references, so a litte air voltage difference and you can go from 21* to 15* pretty quick.
Stage 2 isn't even a tune LOL, it's an injector remap and that's about it.
