DW200 Fuel Pump
Old Dec 17, 2013 | 06:33 PM
blueLNFftw's Avatar
DW200 Fuel Pump
Is this pump a straight swap? Does anything need to be modified in the tank to make it work?
Did a search and only found a thread of some one asking if it needs tuned.
Old Dec 17, 2013 | 06:44 PM
Tjolley's Avatar
thats a down grade.
get the dw300.
y r u changing ur pump
Old Dec 17, 2013 | 07:01 PM
blueLNFftw's Avatar
Fueling problems. Duty cycle running 116% peak and 20ms at 6900rpms. 42's on the 3" pulley. I tested rail pressure and it fluctuates 58-62 psi under wot. So I returned the tester stumped. Only thought is that it is intermittently losing pressure.
Old Dec 17, 2013 | 07:08 PM
mrbelvedere's Avatar
if you are going to get a pump get a pump wally 450
Old Dec 17, 2013 | 08:33 PM
Tjolley's Avatar
wats ur target wot afr
very true
Old Dec 17, 2013 | 09:44 PM
blueLNFftw's Avatar
11.4 ish is the AFR around there.
Old Dec 17, 2013 | 10:09 PM
Tjolley's Avatar
well if ur fuel pressure isnt falling off ur pump is fine.
58-60 is perfict
Old Dec 17, 2013 | 10:23 PM
blueLNFftw's Avatar
58-60 is perfict
Old Dec 17, 2013 | 10:52 PM
Tjolley's Avatar
hmm wat other mods do u have.
Old Dec 17, 2013 | 11:12 PM
blueLNFftw's Avatar
Option b
Front mount heat exchanger
3" cold air intake
Long tube header
2.75" dp
2.5" magnaflow exhaust
Old Dec 17, 2013 | 11:42 PM
ItalianJoe1's Avatar
But it's hitting the 11.4 AFR's?
Old Dec 17, 2013 | 11:43 PM
Tjolley's Avatar
the 42s should be plenty.
i ran a simular setup with nos and a 2.8 for years
Old Dec 18, 2013 | 01:44 AM
You do need to be tuned for a different fuel pump tho right?
Old Dec 18, 2013 | 07:35 AM
blueLNFftw's Avatar
Yes. I am going to try and get my wideband hooked up to my HPT today so I can do a log with my AFR.
I do have a log for anyone that wants to see what it is doing.
Basically: Throttle in and the duty cycle ramps up with the RPM's to about 6k where the duty is ~80%. Pass 6k and there is a cycle spike and they peak out over 110% before redline.
TJolley: Right? And I have seen countless posts that the 42's will do a 2.8. This is why I am like WTF is wrong with my car.
Old Dec 18, 2013 | 07:51 AM
JapEatr's Avatar
South Central *********
Is the tuners config file setup to read duty cycle correctly?
Also DW300 as a minimum for a drop in
The zzp340 and walbro 450 are also excellent choices. Bring your dremel
Old Dec 18, 2013 | 09:44 AM
blueLNFftw's Avatar
Will I need to tune for the huge pump or will it only use what it needs?
Old Dec 18, 2013 | 09:48 AM
yellowsupercharged06's Avatar
post up the log file ... also where did you get your config file from ?
Old Dec 18, 2013 | 10:25 AM
JapEatr's Avatar
not for the pump but if you adjust your base pressure (im assuming you have a RSFS) then you need to update the injector offsets
Old Dec 18, 2013 | 10:27 AM
I think he is still on the stock system
Old Dec 18, 2013 | 10:30 AM
blueLNFftw's Avatar
Yes. Stock system still.
Old Dec 18, 2013 | 11:23 AM
OP's Tune Files and Log
http://www.mediafire.com/download/up...STG2%20Log.hpl
http://www.mediafire.com/download/3h...e_Modified.hpt
not sure if this is how to correctly post these files, but here ya go
Old Dec 18, 2013 | 11:28 AM
blueLNFftw's Avatar
Yup.
Perfect.
Thank you.
Posted is the link for the tune that is on my VCM and the log I took after the write.
Old Dec 18, 2013 | 11:32 AM
his tune was taken off of the HPT repository.
it was labeled "Stage 2, stock"
all the OP did was turn off the VAT, correct me if im wrong
Old Dec 18, 2013 | 11:40 AM
blueLNFftw's Avatar
This is the correct info.
Old Dec 18, 2013 | 05:33 PM
blueLNFftw's Avatar
And i have learned that I have two different renditions of "stock" stage 2 tunes. No surprise there is a huge difference in the fuel tables. The file with the VIN number is the one on my PCM and the other is different. Anyone care to look and tell me which one is for my 42lbs injectors?
Tune I think is right for my car:
https://www.mediafire.com/?b033x20l44oh4x3
Current tune:
