dyno run #2 with Stage II and PB 2.8"
they were 4th gear pulls?
i need a tune, the A/F after 4800 rpm is disgustingly rich, ie. sub 10.9
Anyways i'll post the screen shots once i get them
240.8 whp
238.9 wtq
78F
75% humidity
i really wasn't happy with these numbers and the pig richness
HPtuners tune by Thursday!!
i'll go to the ngk plugs after the Hptune.
240.8 whp
238.9 wtq
78F
75% humidity
still not bad though your hp and tq are preatty even instead of the 241hp/218tq. But a tune is always good. id like to see the gains once u tune it. i have been thinking about the PB 2.8 just want to get my Aeroforce gauge first.
240.8 whp
238.9 wtq
78F
75% humidity
240.8 whp
238.9 wtq
78F
75% humidity
with 238wtq I think that is actually 15~20 more than stage 2 and 240whp is what 2~4 more than stage 2? I think that looks about right dude. a 4th gear pull will under rate you a lil bit and a 3rd gear pull will make you over rated a lil bit since neither is 1:1. Next time at least do one 3rd gear pull just so you can calculate the actual power between both. I am sure there is a formula you can use to figure your power without doing both pulls but I assume it would be easier just doing both when your there.
That tq looks sweet. 238 is a keeper. If you can just lean it out a tad bit, that would be nuts. I wouldn't have went GM Stage 2 though if you plan on getting higher hp and tq numbers. Should've just went with a custom tune instead.
Originally Posted by OniMirage
your sig says 338wtq.
Just click DYNO in my sig.
That 2.8" pulley uped the torque by 26ft.lbs.
That's a nice jump in torque. Don't expect more whp because it takes more power to run the smaller pulley. So those numbers look correct. That's a nice torque jump.
Originally Posted by CobaltBurst
well if you buy a 2.8 pulley then a tune, then why go GM stage 2? all your getting is overpriced injectors right?
yup, i'll do 3 3rd gear pulls and 3 4th gear pulls after the tune.
lemme see if i can get the the 3 pulls uploaded somewhere to host the vids. 4th gear hit 140mph and like 17-18spsi at the rev limiter
lol not if they scan your computer and are like WTF is this its not our programming.... they wont cover it, unless they are dumb....
hell when they installed all the aftermarket ****. the warranty clerk just ignores everything non-gm.
the techs just like having fun with a car that is modded. springs and torque dampener cost me 3 pizzas for the guys. the stage 2 install was only 128.00 employee labor cost.
the main tech who i have work on the car suggested HPtuners just as you guys have
lol if they ignore everything why spend your money on the stage kit?? lol, my dealership is the same way...i know the people really well, my exhaust install was like 50 bucks. for an hour or so.
Hmm, I just had my stage 2 reflash done this morning, and I have the 2.8 sitting on my workbench ready for install. I was geeked about it, but now,,,, what psi did you hit on those runs, the 2.8 should be around 17.5 right?
It should be making boost even quicker than the 3" though right? Not just due to the size, but the fact that the 2.8" pulley weighs like what 1/4 of the stage 2 pulley?
Also I see you didn't put in the BRK7E's yet. Did you at least regap your stock plugs?
And hells yeah warranty FTW
hmm, either I was lied to by the guy I talked to with the 2.8, or intakes make a bigger difference than I thought than.
What is everyone else seeing with the stage 2? I know I hit 15psi leaving the dealership morning because I logged it on my interceptor. I'll see what it hits in second on my way home.
I'd say maybe my gauge is innacurate, but it gets the same signal as the stock boost gauge, so they should be just as accurate (for whatever that's worth) right? Whenever my pillar pod comes in I'll be able to check the interceptor against the stock gauge
Anyways, sorry for taking this off topic a little
hmmmmmm since having installed my injen intake friday I have been getting slightly over 16psi when i was hitting exactly 15 previous to that day.
I just got reflashed this morning, so I cant wait to get out of work and go play, :-)
Cobaltburst:
I'm only at 3300 miles myself. It looks like an intake does increase the boost a little bit. that might be it. You have the raised redline too right?
