Dyno for the SS/SC
It's on a Dynopack Dyno... same style GM uses They take off your wheels and connect to your wheel hubs. A lot more accurate reading, I'm told.
Dyno Pull #1
Dyno Pull #2
Dyno Pull #3
My Friends Shelby GT500 also dyno'd... 480whp 465wtq... I post those videos later, too.
Dyno Pull #1
Dyno Pull #2
Dyno Pull #3
The 1/4 mile run is next. Hopefully sometime this month.
Fujita CAI --- Ingalls "Stiffy" ETD --- GM STAGE 2.8 --- GMPP Performance Cat-Back --- Eibach Sportline Springs --- GMPP Exhaust Manifold --- XCT 2.5" Downpipe w/ Highflow Cat --- Intense Solid TransAxle Mounts
I've got JBP Stage 2 Cams sitting on my couch right now... waiting on the Valve Springs and my 10.0:1 Pistons to arrive. Then I am throwing on Dual Pass Intercooler, Cobra Heat Exchanger, and I think I might even get GM Stage 3 PCM and throw a 50 shot of Nitrous on there!
Your car sounds mean! Must be from the manifold & downpipe. Could just be the vid too I guess. Wow, those are really good numbers now that I see your mods. I'd be curious to see what you pull at the track.
Just wondering why it said Torque Flywheel on the side of your dyno sheet and why you posted it as wtq. Is it calibrated for powertrain loss or something or is it just a misprint, this could possibly explain something if your numbers are high for what you have on your car? What are your mods?
i'd probably take it to another just for comparison.
And I'm not sure what that dip is at 5200 rpm... but I'd really like to know. Maybe belt slip.
Still using 42.5's... I will switch to 60's when I put in the Cams, Pistons, Cobra HE, Dual Pass, and then maybe Stage 3 PCM w/ 50shot of Nitrous. Wet or Dry. I don't know much about Nitrous... someone should PM me and give me the low down on NAWWWZZZ!
using 42.5's?! are u not getting any knock? i thought when u go lower then a 2.9 pulley u need 60's... hmm i must be wrong!
