E-85 ?
Old Jul 16, 2012 | 07:46 AM
silverblur06ss's Avatar
E-85 ?
Alright I know I have seen it but after an hour of searching I am just going to make this thread. What all do you need to run E-85 on the lsj? I already have the areomotive pump and 80's what else do I need? return style?
Old Jul 16, 2012 | 07:54 AM
SatanzSS/SC's Avatar
It all depends on your mods. If you list your mods it will help get you a better answer.
Old Jul 16, 2012 | 08:00 AM
In the process of a build but as of right now:
Diamond pistons & rings
darton sleeves
k1 rods
zzp longtube header
stage 2 cams
p&p head
neutral balance shafts
82# Valve springs
ati ud pulley
aeromotive fuel pump
s2 front mount heat ex
phenolic spacer
opt b.
dual pass
3 inch intake
vibrant exhaust
and right now the m62 with a 2.8 but currently looking for a deal on a tvs with 2.9
oh and like I said 80's as far as injectors go
Last edited by silverblur06ss; Jul 16, 2012 at 08:00 AM. Reason: Automerged Doublepost
Old Jul 16, 2012 | 08:10 AM
Tjolley's Avatar
Im running 60s on e85 with almost the same mods.
I recomend a stock fuel pump works well the aeromotive isnt set up to handle the corrosiveness of the e85.
Old Jul 16, 2012 | 08:23 AM
I am trying to get as close to 400 if not over 400 as I can will the stock pump support that?
Old Jul 16, 2012 | 08:29 AM
Tjolley's Avatar
Hmm good question...im not sure maybe some one will chime in im at somewhere around 340 on e85 with stock fuel pump. Ive done a few mods since my last dyno 330whp
Old Jul 16, 2012 | 11:35 AM
ebristol's Avatar
darton sleeves
k1 rods
zzp longtube header
stage 2 cams
p&p head
82# Valve springs
ati ud pulley
phenolic spacer
opt b.
dual pass
3 inch intake
vibrant exhaust
You won't make 400whp with that build on a 2.9" pulley on the TVS. Realistically, your looking around 350-360whp with a fuel system setup that can support your mods.
On the stock fuel system, your car will probably make ~330whp before maxing the setup.
With a Return Style Fuel system and the stock pump you will make between 340-350whp before maxing out the pump. That is where I am at with a stock longblock and 2.7" pulley on the TVS. I am running about 70psi of FP at WOT and my IDC hits 100% around 7200rpms. I have not tried bumping the FP yet but I would like to get the IDC into the low 90s at WOT. I am pretty sure the stock pump is near its wall.
If you want to make more then ~350whp with 80s you will need a RSFS and a high flowing pump.
Get OTTP's Return style system with the DW300 Fuel pump.
Return Style Fuel System For LSJ
It is a very well put together kit and worth every single penny.
That fuel system setup should be able to support almost 400whp.
With your build and a 2.7" pulley on the TVS, you could realistically make 370-400whp with a really good tune. Breaking 400whp is going to be very difficult without increasing your displacement. But you have the right build to get close.
Old Jul 17, 2012 | 12:47 AM
microgab's Avatar
Those numbers are with E right? And would adding water or meth injection help anything?
Old Jul 17, 2012 | 05:13 AM
Awesome I appreciate it man. I knew it would be hard as hell to make 400 without changing the displacement but I figured I could get damn close
Old Jul 17, 2012 | 11:59 AM
ebristol's Avatar
Yes. Just E85 and they are all approximate. Differences in dyno and tunes can make a big difference on the final numbers.
Guys with ported head have seen between 360-380whp. I personally have not seen any dyno results from a 2.0L TVS cars with ported head and cams. A lot of guys are running them but they are scare of the dyno or something...
I have seen one ZZP 2.4L stroker with ported head and stage 2 cams break 400whp but I can't find the thread at the moment. I am not talking about Turbo Tim's Stroker Redline.
Old Jul 18, 2012 | 12:18 AM
I have area tuning the car so I know the tune will be on the money its all on the build. Is there anything else you guys would add ?
Old Jul 18, 2012 | 08:47 AM
Tjolley's Avatar
Im buildin a 2.4 stroker lsj right now..hopin to be around 350-375 with the m62 on e85 then higher than that with a tvs
Old Jul 18, 2012 | 12:20 PM
advise's Avatar
you might want to dump the 80's and get 1000's
i have a redline of 7k with a tvs and 2.7
running 80's return style and a dw300
and my idc's are 85% with a max fuel pressure of 75psi and a base of 50psi
Old Jul 18, 2012 | 02:11 PM
where can i get a set of 1000s? I have never seen anything over 80s
Old Jul 18, 2012 | 04:29 PM
advise's Avatar
Injector Dynamics 1000cc injector set for Cobalt SS (s/c)
http://www.nolimitmotorsport.com/prod/YPP-ID1000-LK9
Old Jul 18, 2012 | 11:52 PM
Thank you anyone else got any thing else I should throw on in hopes of hitting 400 or more?
Old Jul 19, 2012 | 01:11 PM
ebristol's Avatar
Some water injection would hurt. It will help keep the charged air temps down.
Old Jul 20, 2012 | 05:06 AM
Would it really make a difference while running e-85?
Old Jul 20, 2012 | 09:53 AM
ebristol's Avatar
The lower the charged air temps the better.
Old Jul 20, 2012 | 11:44 AM
advise's Avatar
Just water injection with e85 on a 7 gph jet i saw a 5* drop in iat2
Not worth it
My iat2's hit 135 at the end of a hard pull back to back
Which at 25 psi isn't too bad
Old Jul 20, 2012 | 02:40 PM
microgab's Avatar
Not worth it
Would a bit of windshield washer help then? Not for tuning, only getting those iat2 temps lower
Old Jul 20, 2012 | 03:17 PM
ebristol's Avatar
Not worth it
Really. I would like to see the before and after logs to check differences in Ambiant air temps, IAT1s ect...
Old Jul 21, 2012 | 10:00 AM
5* really isnt worth the effort
Old Jul 22, 2012 | 07:05 PM
ebristol's Avatar
5* is hard to believe...
Old Jul 22, 2012 | 09:53 PM
advise's Avatar
5* was was with a 7 gph nozzle
which at 25psi isnt enough
imo i needed a bigger jet or a small mix of meth in there
but i see no reason because i rarely see anything over 140* iat2
