e85 anyone
Yeah with pump gas its doable but difficult. Its not too reliable to make that much power on pump gas without spray. With e85 it will run cooler which will allow you to run more timing and a leaner AFR (actually richer due to the different stoichiometric value) but the equivalent to leaner on normal gas. So basically you can tune more aggressively on it like you can on race gas. At least thats is my understanding.
im actually getting ready to do it myself. im pushing the stock pulley as far as i can before i pulley down, and this will help get me further. e85 has a higher octane rating, 105 i believe it is. we all know (at least i hope) the higher the octane, the more resistance to knock. therefore, you can make a huge bump up in timing without detonation due to the higher octane. also more fuel is being added to the cylinder, so in theory should help keep cylinder temps down. as it stands right now, if anyone is looking to switch to e85 for mileage, dont. while the price of e85 is around gasoline, you end up using on average 40% more fuel, therefore, costing you more
injectors and a tune. thats all that should be needed. seals and fuel lines should be fine for use with ethanol
injectors will be needed because of the amount of fuel needed. im going to use 60 lb/hr injectors. but keep in mind, this is on the stock m62 pulley. smaller pulleys will need larger injectors accordingly
Last edited by ssyellowss; Mar 26, 2009 at 06:15 PM. Reason: Automerged Doublepost
in whatever modifications you do, just remember when switching to e85 you'll need to push about 40% more fuel than you would with gasoline. so just plan ahead and do it right the first time.
Agreed... e85 is pretty much a cheap race gas but you have to dump a ton of it to make the power, unlike conventional race gas... but i personally know tom aka wickedss and he was running the TVS with 60lbers for a little while and it was fine so i wouldn't see a problem with running the 79s and a proper tune for the e85... and yes higher octane fuel allows you to run more timing, i just hope you plan on buying the supporting mods to get the full potential out of that motor
This is cracking me up I posted this question a couple of months ago and everyone and i mean everyone shot this thought down about running E85! I think it a great way to push the stock pully to its limmets. Im going to do this as soon as i get the money but everone was telling me dont waste my time just run meth same gains pluse keeping mpg. Keep us pore people posted on your findings
Last edited by StevesBlack06; Mar 28, 2009 at 04:35 PM. Reason: Automerged Doublepost
my block and head are still in the machine shop. i dont even have pistons or bearings ordered yet. unfortunalty i prob wont be together till late april or early may due to my friggin pile of bills that i have staring me in the face...
idk.... im waitong on my trans. to get done & my head gasket 2 be made then i should be able 2 get the motor back in the car. But then i will still have the charge pipes 2 make, the exhaust 2 make, the radiator 2 be made, and tires & brakes 2 buy
whos doin the trans work and how much is it gonna cost you? and whos makin your head gasket and why do you need a custom one? what thickness are you looking for? sorry for all the questions im just curious
the trans i cant say yet.... the head gasket is cometic but its the .051" thick(sounds crazy but it wont change my comp.), so thats why
