Eaton M62 Oil fill amount Misconception
Old 07-16-2010, 06:53 PM
EcoTecDriver's Avatar
Exclamation Eaton M62 Oil fill amount Misconception
On many howto's for supercharging the 2.2/2.4 or even just the how to for replacing the oil in the m62 I have seen many people say you need 2 bottles of oil which is over 8oz's, this is wrong!...And all the arguing in the "how to change your M62 oil thread" just confused me more...SO straight from Eatons website here we are....Hopefully this will help clear the questions and misinformation..perhaps a sticky?
Source:http://www.eaton.com/EatonCom/Produc.../FAQ/CT_127016
Old 07-16-2010, 06:56 PM
scotch89's Avatar
3.4 oz thats not much!
Old 07-16-2010, 06:58 PM
No its not, but for the area its going into, it is,
I bought 2 bottles but when I drained my eaton, about 3 oz's came out so it made me stop everything and do some more research
Old 07-16-2010, 07:03 PM
scotch89's Avatar
god im going to be changing my coupler in the sc tonight. i bought 3 bottles of that ****. so no more 2 bottles then? 3.4 is the right amount!
Old 07-16-2010, 07:09 PM
Thats why this needs to be a sticky
Old 07-16-2010, 07:10 PM
scotch89's Avatar
x2 for sticky worth!
Old 07-16-2010, 07:13 PM
jonxxxedge1's Avatar
i had 2 bottles in mine before i sold it. no probs with it
Old 07-16-2010, 07:14 PM
well you put too much
even more then what a TVS would need.
Old 07-16-2010, 07:21 PM
scotch89's Avatar
so have you put just 3.4oz in yours? does it sound fine????
Old 07-16-2010, 07:22 PM
05Slowline's Avatar
zzp says you need 6......
Old 07-16-2010, 07:25 PM
scotch89's Avatar
6oz? or bottles lol
Old 07-16-2010, 07:28 PM
05Slowline's Avatar
6oz.......
Old 07-16-2010, 08:31 PM
So you trust Zzp over the company that manufactures the supercharger? really? come on....
Originally Posted by 05slowline
6oz.......
wrong, you guys are dense......
its not installed yet, but i drained out 3oz!!!!!!!!!
Last edited by EcoTecDriver; 07-16-2010 at 08:31 PM. Reason: Automerged Doublepost
Old 07-16-2010, 08:35 PM
kingg5's Avatar
why are people doubting the manufacturer? are u seriously that ****** stupid?
but of course...that way u spend more money...funny how a business works
Old 07-16-2010, 08:42 PM
selfinfliction's Avatar
my manufacturer's manual from gm states that i need to put 5 quarts of oil in my LSJ during an oil change.
since the manufacturer can never be wrong, i should probably go drain out 1.5 quarts asap huh?
Old 07-16-2010, 08:43 PM
kingg5's Avatar
eatons not gm.
Old 07-16-2010, 08:49 PM
guess I have to call eaton and record the conversation next
You fail big time at reading, Im talking about the actual oil in your M62 not the motor genius
Last edited by EcoTecDriver; 07-16-2010 at 08:52 PM. Reason: Automerged Doublepost
Old 07-16-2010, 08:53 PM
quit being a tard just because you think you found some uber top secret thing that no one knew before.
it's on the ******* eaton faq. just because they suggest 3 oz doesn't mean it's the best. maybe the 6oz works better at high rpm that the oem pulley will not see on the m62 because of the higher amount of windage inside the case. the higher levels of oil could help reduce the windage or at leats make sure that there was sufficent oil in reserve for lubrication while windage levels were high.
you fail at reading, Im talking about the actual oil in your M62 not the motor genius
no you fail at comprehension. you were just asking if someone trusted zzp over a manufacturer and then you try to bash me for giving a perfect example of a manufacturer giving bad information.
your thread is complete ****.
Last edited by selfinfliction; 07-16-2010 at 08:53 PM. Reason: Automerged Doublepost
Its not secret, its info that this site failed at providing, dont be a *******.
Throw in the foul language show your education.....if im wrong please show me valid info, instead of cursing like trailer trash.
Old 07-16-2010, 08:57 PM
and your idiotic uninformed assumption and failure to understand the entire scope of the sticky theory deemed valid for all applications due to the resource provider, displays the lack of education you possess.
dude i've got 2 degrees and i'm working on my masters, if you want to have a wordsmithing contest, i will make you feel bad about existing.
Old 07-16-2010, 09:00 PM
Pedobear's Avatar
Old 07-16-2010, 09:01 PM
I give up....you cant have a civil discussion on this site, its impossible....
Originally Posted by Pedobear
really? your going to turn on me to?
Last edited by EcoTecDriver; 07-16-2010 at 09:01 PM. Reason: Automerged Doublepost
Old 07-16-2010, 09:03 PM
Pedobear's Avatar
nope i turning on this site that, i dont see the point in trying to help ********, i would post it somewhere where its apreciated hint hint
Old 07-16-2010, 09:04 PM
sure you can, just don't bust out like you discovered some secret and instantly state that everyone is wrong form what they've been doing just because you are going by a single resource of information that takes into affect, a singular setup. people are spinning these blowers 50% faster than from the factory and that changes alot of dynamics. but instead of you saying "hey check this info out" you busted out just stating everyone is wrong except that one chart.
^^ username ftw LOL!
Last edited by selfinfliction; 07-16-2010 at 09:04 PM. Reason: Automerged Doublepost
Old 07-16-2010, 09:11 PM
cubaniche's Avatar
Okay I have a valid question. Eaton says to use 3.4oz but people have used 6oz. The full 6oz fits in there no prob? Do we have proof that using more oil helps with the higher load being put on the m62 by using smaller pulleys and higher revs? Do we have any proof that it doesnt make a difference?
Just wondering why theres two groups saying different things is all.
Quick Reply: Eaton M62 Oil fill amount Misconception
