Endurance racing LSJ Miata Swap
Hi everyone,
I need some recommendations. We are building an 02 Miata to endurance road race. I originally bought an LNF with transmission from an 08 solstice to swap into the car. We have since decided the tuning is going to be a nightmare. I now plan to buy an LSJ to use instead. We will modify the supercharger snout to fit and add a cable throttle body. ECU will be a Megasquirt MS3 pro. All the cooling mods and a huge heat exchanger for the intercooler will be used. Fuel is restricted to 93 octane. Rev limiter will be set at 7k. Full 3 inch straight exhaust with header. I want to get 240-250whp that can be beat on for 8 hours a few times a year. Can these motors handle that? What other mods should I do? I'd like to keep the longblock as stock as possible. Am I asking too much? Thanks |
Personally if I was going to push it hard for 8 hrs at a time I would put good rods and pistons in it, crank should be ok. The last thing you want is engine failure. Now if it was only going to be an hour or something that's different.
Maybe someone could chime in if the stock oil cooler can handle that. Seems to work well but maybe a external front mount would be nice.
I'd think if you kept the oil temp under control you'd be golden |
I planned to do a remote front mount oil cooler. Forgot to mention it. Transmission and rearend will also have coolers, plus one for the driver 😉
Nova, if I have to do rods and pistons I would go the Le5/9 route and put an LSJ blower on it. How stout are the internals of the LSJ
Ecotec 3.0 for life!
lol le5 internals
Originally Posted by mrbelvedere
(Post 7687755)
lol le5 internals
(Post 7687767)
I meant putting a forged rotating assembly in an LE5 if I'm upgrading internals
(Post 7687771)
the le5 has a dog shit rod to stroke ratio 1.54 your best bet would be to run a lsj crank in a le5 block with a 2.2 rod raise the compression to 11.5 so you can keep the blower in its most efficient range and re sleeve the block with better sleeves then stock so you will be able to setup the piston to wall clearances and it will also give you better ring control and run a lsj head
No, you need a 2.4 block for 88mm pistons unless you wanna pay for big boy sleeves.
(Post 7687771)
Shorter rods mean the overall height of the block can be shorter, which means the overall weight of the block can be lighter. The engine will typically pull more vacuum at low RPM, which means better throttle response and low end torque (good for street performance and everyday driving). Spark timing can be advanced a few degrees for some additional low speed torque, and the engine is less prone to detonation, which can be a plus in turbocharged, supercharged or nitrous applications. |
Ecotec blocks are all the same height.
(Post 7687800)
Being the same was a manufacturing decision to cut costs. |
Originally Posted by HGT
(Post 7687796)
Not a lot of advantages to the lower R-S ratio but there are some:
Shorter rods mean the overall height of the block can be shorter, which means the overall weight of the block can be lighter. The engine will typically pull more vacuum at low RPM, which means better throttle response and low end torque (good for street performance and everyday driving). Spark timing can be advanced a few degrees for some additional low speed torque, and the engine is less prone to detonation, which can be a plus in turbocharged, supercharged or nitrous applications. low rod to stroke ratio heavy rod angle accelerated wear on the thrust sides on the piston and rings and rod bearings higher piston speeds cylinder head does not flow as well and less cylinder filling its harder on the pistons and pins when going through tdc you raise compression and increase boost you just make things harder on the rotating assembly now you talk about running a short rod and shortening up the deck for weight loss on a overhead cammed engine when you bring the cams closer to the crank you retard cam timing so now you have to add a bunch of timing to make up for the slow cam timing and that can be hard on rod bearings as well |
(Post 7687804)
"Shorter rods mean the overall height of the block can be shorter"
(Post 7687804)
Not if we are being specific to the Ecotec block....
Like I said... Not a lot of advantages. |
Edited above
(Post 7687809)
when a company does that they have to change the cam timing
In any engine I have ever seen built for rpm and efficiency the higher the rod ratio the better. Longer rods also allow you to use shorter pistons (wrist pin height) which saves weight, and makes the engine easier to rev and take rpm.
The 406 I have in the Nova came with a crappy ratio I went from 5.56 rods to 5.7 and if I wanted to do more clearance work I could have went 6.0. Cut down on piston weight, and allowed me to be able to spin the motor a little higher. |
(Post 7687829)
I am sure those that are doing that as a weight saving measure are accounting for that as well.
le sigh
(Post 7688012)
le sigh
