Engine Coolant Temp. Sensor.... Maybe???
Old Jul 3, 2009 | 08:43 PM
Red07Coupe's Avatar
Post Engine Coolant Temp. Sensor.... Maybe???
Here is what my car is doing;
- When I first turn it on, could be in the morning or after I've been driving it for a bit, the fan comes on (A/C is off)
- The coolant temp indication on my DIC still operates and indicates a normal cooling condition.
- When a friend of mine recently connected his HP Tuners, the car constantly indicated an overheat condition (I think around 120 degrees)
- The car dosn't appear to be overheating
- The I/C pump appears to be working because I can feel coolant flow through the lines of my OTTP heat exchanger.
Alldata DIY says its the (ECT) Engine Coolant Temp. Sensor, but my dad, who is a mechanic, thinks its the thermostat.
Anyone else ever have the same kind of problems?
Thanks in advance for any advice or help.
Old Jul 3, 2009 | 09:43 PM
HunterKiller89's Avatar
im confused. what is the actual problem? just what the HPT scan is saying? and you said an overheat condition, and then posted 120*...which is definitely not overheating
Old Jul 3, 2009 | 09:45 PM
Bad05SS's Avatar
same thing im going through my car been at the shop for a week now so good luck
Old Jul 4, 2009 | 03:44 AM
SSJit's Avatar
hey bro im having the same problem.. my fans stay on even when the key is on but the car isnt running.. i changed the ECT sensor and that didnt do a thing.. someone else had the same problem also and he told me that he replaced his thermostat and that fixed it.. sounds weird but i guess if the computer finds a problem with the thermo, it automatically kicks the fans on as a safety precaution..
Old Jul 5, 2009 | 08:41 PM
Red07Coupe's Avatar
Thanks man, I'll try replacing that first. I'll let you know how it goes.
Old Jul 11, 2009 | 02:29 AM
SSJit's Avatar
did u ever get a chance to change out that thermo man??
Old Jul 11, 2009 | 03:26 AM
wtpcobaltss's Avatar
coolant temp sens is bad..its happens alot to most gm vehicles..i doubt its the thermostate other wise u would have a high reading and the car wouldve overheated by now...but to be on the safe side dont be hard on it.
Old Jul 11, 2009 | 08:23 AM
Red07Coupe's Avatar
No I haven't, Waiting till next week.
And if the coolant temp sensor is bad you would think that the indication givin by the DIC would not be functioning. I dunno, I'll probably replace them both
Old Jul 11, 2009 | 08:25 AM
G85 SS's Avatar
I'm guessing you have a bad thermostat.
Old Jul 11, 2009 | 08:28 AM
Red07Coupe's Avatar
Ya same here
Old Jul 13, 2009 | 11:58 AM
SSJit's Avatar
ya man like i said i changed the sensor and it didnt do a thing to stop the fans.. relays are good too..so im still gonna have to change out the thermo n see what happens.. it looks like such a pain to do.. im gonna wait till i can get ahold of a lift n do it on there
Old Jun 7, 2010 | 10:38 PM
2006superchargedss's Avatar
old thread but what was wrong in the end if you remember ?
Old Jun 7, 2010 | 11:37 PM
Red07Coupe's Avatar
The I/C pump turned out to be intermittent, the cars lease comes due in December so I'm not going to bother fixing it.
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
grampss
Sep 27, 2015 08:51 PM
