Engine Misfire and Oil Leak??
Old Oct 24, 2013 | 10:16 AM
hopewillfall's Avatar
Last night I was driving on the express way. I wasn't beating on the car or anything (Cruise control at 70mph) and out of no where, my CEL started flashing. I pulled off on the next exit which luckily was my exit, and took the car home. The car is shaking real bad so I feel like one of the cylinders is not firing. Im thinking maybe one of the coils went bad and that may be the cause, however, I lightly reved it a few times in the driveway to see if it would smoothen out and I notice smoke coming out of the engine compartment. I shut the car off and saw oil everywhere between the master cylinder and the valve cover. I have no idea why the car is puking up that much oil nor do I no where its coming from (I havent looked yet, this occured last night at 1130pm) but Im hoping it's nothing major. Im thinking it could just be a clogged pcv valve, but on the other hand, I have installed a catch can before the pcv so I find it hard to believe it would get clogged. Maybe I threw the spark plug out of the head? I feel like that would require me beating on it, also if it's like my other cars, if the spark plug came out wouldnt I hear the air pressure coming out of it? I really havent looked at it yet and Im stressing out about it. Just wondering if anyone has had similar problems and what exactly needed to be fixed in this case. Its a 2005 cobalt by the way, almost 100% stock with a zzp CAI. 103,xxx miles
Old Oct 24, 2013 | 10:25 AM
574's Avatar
574
Could be many things. You need to investigate more
Old Oct 24, 2013 | 10:43 AM
mrbelvedere's Avatar
this is the performance section not my car is broken section that is located here Problems/Service/Maintenance - Cobalt SS Network I suggest you ask these types of questions over there
do a leak down test and check and see if the dipstick is popped its not a pcv problem
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
Trav3480
Oct 1, 2015 08:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
