engine power reduce message!????
Old Dec 22, 2009 | 09:48 AM
jonathan923's Avatar
Question engine power reduce message!????
guys, i have this issue since yestarday morning. for some reason when i first turn on the car in the morning the car turns on normal and then i get the eng pwr reduce message, so the car starts to iddle a bit harder then normal and its almost impossible to drive. after a while of turning it off and on and it passes 130degrees in temp then it turns on normal and it runs fine afterwards...this is weird but does anyone have any suggestions or inputs about this...
Old Dec 22, 2009 | 09:50 AM
umrdyldo's Avatar
I really have no idea, but my gf's jeep is doing the same damn thing.
Her dad thinks it's the cam position sensor. You might need a relearn.
Old Dec 22, 2009 | 09:53 AM
MrSlickSter06SS's Avatar
humm that is odd, I wish I new but I wouldnt be to sure, inless maybe something was cloged or something and its just throwing that message, im not sure hope you can figure it out, or if someone else atleast know..
one of my codes was crankshaft sensor relearn on something like that..could that be causing this issue? i need more inputs so i can be sure...but thanks anyway man!
Old Dec 22, 2009 | 09:59 AM
tapoutZ06's Avatar
My Z06 had the same problem and it was moisture in the TPS.. Took it to 2 different Dealerships and they couldn't figure it out. Finally took it to my performance shop and had it up and running as good as new. Tricky part is if you OHM it out to see if the signal is within parameters it checks out okay but has a weak connection when moisture is present.
Good luck man..
That could do it.
Old Dec 22, 2009 | 12:19 PM
ill keep you posted on this in case anyone ever has it and ill post up the problem and solution when i find out about it. thanks for the inputs guys
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
patooyee
Oct 1, 2015 01:07 PM
