Engine questions
Old May 1, 2009 | 07:31 AM
victoryss's Avatar
Engine questions
So say "theoretically" that my #4 had very low comprssion and I needed to re-build the motor. I need Pistons, Rings, New Head Gasket, ARP Head Studs. Anything else I am missing??
One question I am pondering is to leave it at 9.5:1 or should I bump it to 10:1? I plan on running a 2.8" from here on out with the addition of a 50-110 shot of nitrous and a ported head....... What are some things I should consider while trying to make this decision?
Old May 1, 2009 | 07:41 AM
GreyDog72's Avatar
go with the 10:1 for sure. that motor can handle it from what half these guys are running with a ported head and 2.8 pulley you'll be fine. the 110 shot im not sure im not a nitrous person but a 50 shot ude be fine.
Old May 1, 2009 | 08:18 AM
Zach06CobaltSC's Avatar
On the nitrous side, I will let you know how it goes when I run the 50shot on the stock internals. I am using the 35shot currently for tonight, but on monday at 2 I am dyno'ing with the 50shot, wish me luck lol.
Old May 1, 2009 | 08:22 AM
damien's Avatar
Keep stock compression. Need rod bolts, silicone, 1 crank bolt and 2 cam gear bolts. Tons of rags, oil and extra coolant.
Old May 1, 2009 | 08:34 AM
victoryss's Avatar
Thanks for the parts, but don't just say stay stock compression. Why?? I like to learn and understand things not just do them
Old May 1, 2009 | 09:12 AM
damien's Avatar
Tuning. In order to run higher compression you gotta pull some timing. The power difference because of this is negligble
Old May 1, 2009 | 09:47 AM
If you want me to do your tuning let me know victoryss.
Old May 1, 2009 | 10:41 AM
GreyDog72's Avatar
you ever wounder why the Z06 is so fast other then its a vette? its be the compression it like 11.5:1 or somthing. The higher compression you go the more power you make. Now, the saying is low compression high boost or low boost and high compression. With a 10:1 compression its about inbetween. Your motor can handle the little extra compression with the same amount of boost. But the reason im not saying anything about the 110shot is because with that little extra compression i dont know if it is too much.
Old May 1, 2009 | 10:50 AM
ShortStack's Avatar
Youll get higher tq numbers with the higher CR. Not like OMG higher... but noticable.
Youll end up pulling more timing using the higher CR, it wouldnt be beneficial.
The better "numbers" come with using a lower CR, and a higher boost, than a higher CR, with lower boost.
Old May 1, 2009 | 10:51 AM
victoryss's Avatar
very good. the part that i'm hung up on is the 110 shot
Old May 1, 2009 | 10:53 AM
BLAZIN07SS's Avatar
I'm too JDM for you
quite a bit of misinformation in this thread
victoryss's Avatar
so bitch clear it up noaw
Old May 1, 2009 | 10:57 AM
ShortStack's Avatar
Im not sure why zach is still hung up on a 35 shot...
If you have the LSJ... and your on the m62... i dont see why a 100 shot wouldnt work?...
It would DEFFINATLY have to be a progressive shot though.
Old May 1, 2009 | 10:58 AM
BLAZIN07SS's Avatar
I'm too JDM for you
nitrous loves high compression but you will also be moving quite a bit of boost, i would stick with stock compression. the higher compression will raise torque a little but it comes with not being able to use as much boost, which i know you want to go turbo later so still with stock CR
thats a lot of spray dude. lol
Old May 1, 2009 | 10:59 AM
victoryss's Avatar
hrmmm decisions, decisions.........
Old May 1, 2009 | 11:00 AM
ShortStack's Avatar
Well think... average hp output is around 270... a hundred shot would make it 370...
if you use a progressive controller.. not all the nitrous is shot at once, so the engine will be a little safer without all that power hitting at once.
Old May 1, 2009 | 11:02 AM
GreyDog72's Avatar
.5 more CR wont hurt anything with boost. a 35 shot will prevent any knocking with the same amount of boost. You dont have to lower the boost if your increasing CR by .5 the 35shot will keep your temps down so you wont really need to pull much timing.
Old May 1, 2009 | 11:04 AM
BLAZIN07SS's Avatar
I'm too JDM for you
gotta pull a bunch of timing as well
umm what? nitrous increases cylinder temps dude
Old May 1, 2009 | 11:05 AM
GreyDog72's Avatar
cylinders yes, compressed air before it enters no
Old May 1, 2009 | 11:06 AM
ShortStack's Avatar
The GM build book uses 10:1 diamonds...
they do state they raised the CR from stock to 10:1.
Old May 1, 2009 | 11:08 AM
damien's Avatar
I lol at them man..
Old May 1, 2009 | 11:09 AM
victoryss's Avatar
Hrmmmm well with a ported head and a 2.8" and supporting mods theres a m62 running around 325whp i want 400whp on spray on the m62
damien's Avatar
Gm also is a race car, not street driven.
Old May 1, 2009 | 11:11 AM
victoryss's Avatar
I'm not talking about a gm car....
Old May 1, 2009 | 11:28 AM
ShortStack's Avatar
OMG.. so your saying if i put race stuff in my car i cant drive it on streets?
naaaaaaaooooo!!!!!!!!!!!!!
