Engine RunUp Meth kit on cobalt ss blades ok?
Hey guys,
well, i ran the same meth kit on my s/c cavalier (m45 s/ci believe) and had no problems with corrosion on the blades. I know theres been talk about whether there is teflon on the blades or not (good or bad?). now, unless a company sells the sandwich plate seperatley, i'm going to run the kit before the s/c so it goes thru the blades. Is that ok on this s/c? Or is the meth going to eat the rotors like on the new 3.8l gtp s/cers (or so i've heard). Thanks! Nate |
Intense makes the spacer plate to run fluids in after the blower, but honestly you can run it through the screws all day long without issues.
Originally Posted by StreetDreamz
(Post 877411)
Nate |
there were some people running it before but it would be wiser to run after. You'll have a better place to mount the nozzles and it'll be more permenant.
Originally Posted by Chevypowered
(Post 877425)
I run mine before the blower. Easy install, no problems thus far.
Originally Posted by c24na
(Post 877434)
Not really wanting to drill/tap the manifold. Would have a pernament spot on the intake :)
Hasnt this been talked about before, maybe iam wrong but i believe i heard there is not teflon on the blades.
Originally Posted by patathSS
(Post 877452)
