engine temp
you want your engine to stay at 83 C or 180ish f when cruising or even more. not much less. that should stay constant. the fmhe is used to cool intake air temps as they come through the manifold
Our cars run two separate coolant systems. One for the engine and one for the supercharger. Your H/E will lower your IAT2's (intake air temperate after the supercharger.) You'll gain power and run safer.
while your stock, if your ic pump is working well, youll be in good shape with just that. even without the ic pump working. i ran mine for about a year and a half with a burnt up ic pump. and i live in south alabama. temps are already scorching
TVS with stock pulley, 60lb injectors, CA H/E, Meth Injection, CAI, 2 step colder plugs and a few other things. Had no issues but it did cause abit of back pressure, causing abit of hp loss.
patooyee
Oct 1, 2015 01:07 PM
z28addiction
Sep 28, 2015 12:03 AM
