Engine temp very low.
I've had this problem for the last two winters, and brought it in to get fixed three times. In the cold weather(40f or lower about) my car will not warm up at all while driving. Idling it will but as soon as you start to drive it will drop dramatically. In 30 degree weather while driving I'm lucky if the car will get to 120f.
Problem only happens when it's cold.
Check engine light comes on after a while and the code is p0128. Had the thermostat replaced last year, and they also told me they replaced the engine coolant sensor, but I could be mistaken.
Had the car reflashed by GM
And just picked it up again today. They told me it was the thermostat again. Five minutes down the road my car was still at 93 degrees ha. So obviously it's not fixed and going to throw another code.
Any ideas?
P.S. my fans do not seem to be running when idling . Can't tell when I'm driving though.
Any ideas?
If your in the cold, you can put a piece of cardbord to block the airflow over part of the radiator. Similar concept to what the big semi trucks do with that canvis in front. This will keep you from overcooling the engine. Just make sure you dont block TOO Much. But i agree with the other people, check your thermostadt. You can test them in a pot of water on your stove with a thermometer if you want.
I used to have a 1993 Dodge Shadow, that would go through thermostadts almost annually.
All I know is that they replaced the thermostat last year because it was stuck open, and they replaced it again yesterday, because it was stuck open.
If the weather were 50 degrees today the car would heat up perfectly, and stay that way during driving, idling, or whatever.
Hmm.. Strange because I am almost in the same position.. Ever since it's been getting colder, my car doesn't get to the normal 190°F temp, it hardly goes above 160 for that matter.
I was going to replace the thermostat, but if that doesn't fix it then I'm stuck in the same boat as you.
Well guys it sounds like either three of these issues. One when they installed ure thermostat they installed a lower heat range stat. Two they used more water to make a 20/80 coolant mix and its causing ure stat to break the spring. Three ure stat just went bad again or they installed it backwards.....
Just wondering: If it's installed backwards, wouldn't the heat sensing canister part, be on the cold side of the valve? Thus makeing the engine have to get even HOTTER before it starts to open? Unless the water flow is pushing against the spring like a check valve.
It would be interesting to see what they do with a car under warranty with this problem though.....
And sometimes it IS nesscary in extreme cold conditions. (That the OP are not in however)
If coolant flow is goiing against a reversed thermostat it will cause it to over heat unless ure pressure is outstandingly high then it can open the stat itself.I've seen it happen.
patooyee
Oct 1, 2015 01:07 PM
z28addiction
Sep 28, 2015 12:03 AM
