Error codes...need some help!
ok, i am throwing a P0171: System too Lean (Bank 1), and a P0335: Crankshaft Position Sensor A Circuit Malfunction....ne ideas what would cause these?? (other than the obvious issue with the crank sensor)
Means your running to lean. id go get it retuned again asap. and for the second is. do you spray that oil **** that comes with the filter? if so then that will mess with the sensor
::sigh:: the 171 code. and 172 code is not caused by oil on the maf. it is caused by the ltft trims being above 17.6 +/- for an extended period of time. this happens a lot in the winter time.
clear it and move on.
