everyones boost numbers
Old Jul 18, 2006 | 08:51 AM
  #51
p7x's Avatar
p7x
18 PSI = 124 KPA with GM stage 2 and PB 2.8" in third and forth approaching 7000 rpm.
Stock I sw 13.1 PSI.
Old Jul 18, 2006 | 08:52 AM
  #52
Allshot's Avatar
17 - 18 Psi
Old Jul 18, 2006 | 09:33 AM
  #53
06blackg85ss's Avatar
I read it with an aeroforce I'm a hair over 21 now
Old Jul 18, 2006 | 09:36 AM
  #54
BLKSS's Avatar
15.5 Stock! Oh yeah and stage 2 but who cares?
Old Jul 26, 2006 | 09:18 AM
  #55
RickZ28's Avatar
80 KPA - 11.6 PSI
Mods
K&N CAI
GMPP Performance Catback
Old Jul 26, 2006 | 10:23 AM
  #56
whitted2268's Avatar
19 psi
Old Jul 26, 2006 | 10:27 AM
  #57
1stbluSS's Avatar
cool air 14.5
summer air
13
Old Jul 26, 2006 | 11:39 AM
  #58
OneFast20's Avatar
Stage 2 - 15 psi
Old Jul 27, 2006 | 05:33 PM
  #59
sethallen's Avatar
17.4 PSI with 2.8", and GM Stage 2
Old Jul 27, 2006 | 05:46 PM
  #60
memphisr24's Avatar
16.5 - 17 psi....Soon hoping to hit 20 in a month or two with a 2.6 or 2.5 inch pulley
Old Jul 27, 2006 | 06:37 PM
  #61
mattyfinch's Avatar
15 now, 21 once everything is back in and tuned
Old Jul 27, 2006 | 06:45 PM
  #62
foci's Avatar
17.5
Old Jul 27, 2006 | 06:47 PM
  #63
WSFrazier's Avatar
21-22 psi
Old Jul 27, 2006 | 06:49 PM
  #64
*TRIX*'s Avatar
21 psi faster than ur average cobalt
dun worry about it
Old Jul 27, 2006 | 06:52 PM
  #65
06black's Avatar
EDIT---
now 20-22 depending on outside temp.
Old Jul 27, 2006 | 09:00 PM
  #66
More_BoostSS's Avatar
17 psi ----injen cai install monday
Old Jul 28, 2006 | 12:29 AM
  #67
llavalle's Avatar
Just finished my install of an Automoter UltraLight 2 boost gauge(mechanical)...
I hit 12 just before hitting the rev limiter in 3 and 4th
all stock.
Old Jul 28, 2006 | 03:51 AM
  #68
andy0405's Avatar
I'm holding 13psi aem cai and custom cat back exhaust
Old Sep 13, 2006 | 10:21 AM
  #69
HighPSI_LowCC_Speed's Avatar
This Is Misinformation....see Link...
Originally Posted by mrdoc442
with the factory U.S boost gauge can answer this thread intelligently unless the needle on the boost gauge is exactly on 10, 15 or 20. Even then you are believing the typically erroneous factory gauge to be accurate. The demarcations between these numbers are not logical and make no sense. I contacted Autometer and spoke with a couple of their tech's who work for the company who made the gauge, and they were not able to read or interpret it. They said they just built the boost gauge the way GM specified, and in the future would endeavor not to put their name on something so shoddy. Scan tool or tuner info would be much more reliable for those fortunate enough to have access to them. The Canadian gauges make a whole lot more sense. Autometer suggested I warranty mine for a Canadian version. The best thing to do would be to get an after-market Autometer liquid filled boost gauge. I had them on other boosted vehicles and they appeared to be reasonably accurate.
I have seen many folks reference 12.5 # boost with the stock 85 MM 3.346" pulley. This is incorrect. According to the Cobalt SS S/C factory shop manual, under engine controls, 2.0L, 6-1395, "Max engine boost is 83 kpa/12 psi."
I stumbled on this chart on another forum and thought I'd share it for anyone interested. I did the math with my car-2006 SS S/C-Stage II, K&N factory filter in opened up filter box-Borla cat-back, extrude honed exhaust manifold-2.8" pulley, and the reference numbers for loss at altitude are very close to what I calculated using the complicated (for me at least) formula given, for each altitude with my car. Remember I am not a mathametician. The numbers to the far right are subtracted from the boost you should have. For example, I should have about 17 psi with my mods at sea level, but at my altitude of 4000' my boost gauge shows 15 psi (-2 on the graph for 4000').
Altitude/ Air press(in. Hg)/ Air press(psi)/ Loss as referenced to sea level (psi)
Sea level/ 29.92/ 14.7/ 0
1000 ft/ 28.86/ 14.18/ -0.52 psi
2000 ft/ 27.82/ 13.67/ -1.03 psi
3000 ft/ 26.81/ 13.17/ -1.53 psi
4000 ft/ 25.84/ 12.7 / -2 psi
5000 ft/ 24.9 / 12.23/ -2.47 psi
6000 ft/ 23.98/ 11.78/ -2.92 psi
7000 ft/ 23.09/ 11.34/ -3.36 psi
8000 ft/ 22.23/ 10.92/ -3.78 psi
9000 ft/ 21.39/ 10.51/ -4.19 psi
10000 ft/ 20.58 / 10.11/ -4.59 psi
I had to do this piecemeal to fit this screen-hope it shows correctly. I can't get them to line up, use the dividers and read corresponding with dividers at the top.
This chart is "ideal" ie., it assumes 100% efficiency and doe not factor losses due to backpressure or heat. S/C boost is somewhat of a black science, with many variables to consider. However in my case, at 15 psi at least, it is right on, considering my mods and altitude. Everyone's situation is different, so just use the table as a ballpark guide, don't consider it to be 100% exact. Remember, noone so far has been able to tell me how to read the factory gauge in between the major numbers. Not even Autometer tech's can tell me how to read their gauge. I E-mailed Chevrolet and they said they would refer me to someone in engineering who could tell me how to read the gauge. Never heard back, so I guess they can't read it either. I have raced cars for many years, and I have never seen a gauge that is any harder to read than the factory (U.S. version) Autometer boost gauge in our S/C cars. It moves up very quickly, and it is hard to watch the road and check the gauge, trying not to run up on the rev limiter-trying to look at the tachometer at the same time. I have noticed that since I installed the Stage II, my boost does not start to drop back at 5600 to 6000 rpm. With the boost bypass mod, I don't know if that has any affect on the boost gauge's calibration/accuracy or not. But I would suggest being careful with that mod. The factory shop manual states that damage to the engine can occur if the boost bypass valve is stuck in the position to allow full boost, unchecked.
Maybe the factory Aurometer gauge isn't off that far after all.
Doc
THIS IS INCORRECT....SEE THIS POST FOR EXPLANATION....
https://www.cobaltss.net/forums/show...5&postcount=43
Old Oct 16, 2006 | 11:03 PM
  #70
victoriaskimmer12's Avatar
18
Old Oct 16, 2006 | 11:07 PM
  #71
wikkymaster's Avatar
19, but all i have to do is turn a little controller that sits right by my feet
Old Oct 16, 2006 | 11:13 PM
  #72
R&C_rallySS's Avatar
12.5 Stock
Old Oct 16, 2006 | 11:17 PM
  #73
denny's Avatar
Set my boost controller to 16.5-17PSI.
Old Oct 17, 2006 | 01:39 AM
  #74
Blown 4-banger's Avatar
Now with my 2.6" pulley I hit 18.5 psi
Old Oct 17, 2006 | 01:48 AM
  #75
twzted's Avatar
17-18
