exhaust cutout
Old Dec 13, 2008 | 09:49 AM
hockeylx92's Avatar
exhaust cutout
does anyone know how much extra hp an ss/sc will gain with an electric exhaust cutout???
Old Dec 13, 2008 | 10:59 AM
mcphatty's Avatar
what mods do you currently have?
Old Dec 13, 2008 | 11:37 AM
Erod's Avatar
Moderator Alumni
Do not post the same question more than once.
Read my sig. Moved to correct section.
Old Dec 13, 2008 | 02:29 PM
hockeylx92's Avatar
none. its stock
Old Dec 13, 2008 | 02:50 PM
krazycobalt's Avatar
Why would your first mod be an exhaust cutout! thats retarded
Old Dec 13, 2008 | 05:35 PM
mcphatty's Avatar
exhaust cutout on a stock 2.0 will lose horsepower
Old Dec 14, 2008 | 04:24 PM
hockeylx92's Avatar
what would you suggest for a first mod then
Old Dec 14, 2008 | 04:27 PM
Perfect.disguise's Avatar
Start by a CAI/ABM,then cooling mods, then exhaust and then a "Stage". Mounts and whatnot would also be good to throw in there somewhere
Old Dec 14, 2008 | 09:28 PM
car_guy_09's Avatar
I was also planning on doing a header downpipe then a cutout, And leaving everything from the cat back stock. But was worried about not having enough back pressure, And was going to start a thread like this asking about it.
At what point would it be beneficial running a cutout?
What if i put the cut out after a highflow cat?
The reason i want to run the cutout is, like the stock exhaust just cruising but want to be able to make some noise at times
Old Dec 14, 2008 | 10:17 PM
Most header/downpipes sound pretty raspy on the factory catback.
Old Dec 14, 2008 | 10:22 PM
car_guy_09's Avatar
Damnit.. What exhaust would you recommend for quiet power?
Old Dec 14, 2008 | 10:51 PM
I have a Vibrant header/downpipe and a custom Magnaflow catback full 2.5. I used two mufflers instead of one muffler and a resonator. Driving around it sounds pretty stock (atleast on the inside).When I get on it, it sounds good and not ridiculus. Here is the old thread. Note it was before the header/downpipe. Is about the same noise wise but it "smoothed" it out a bit so it's not so poppy.
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/custom-exhaust-info-pics-vids-126913/
Old Dec 14, 2008 | 11:01 PM
car_guy_09's Avatar
I pmd you to stop the thread jack lol
Old Dec 14, 2008 | 11:04 PM
EXsoccer1921's Avatar
corsa touring
Old Dec 15, 2008 | 01:27 AM
Hey question and sorta a thread jack... haha im running a zzp header and DP combe 2.5 and 2.5 exit on to stock catback with magnaflow muffler..... Sounds a little raspy woundering if I should look into a 2.5 cat-back? sound any better?
Old Dec 15, 2008 | 09:08 AM
ShortStack's Avatar
1. Do a search on backpressure, youll find a bunch of crap telling you how stupid you would have made yourself look if you posted a thread on backpressure. You really shouldnt be even thinking of an exhaust cutout at the moment, at all. Really, it would be a waste of money at this point in time. Wait till you have a little power. And more than just an intake and exhaust.
2. krazy, do you have a cat? If not, get one that will take away rasp. Cheaper alternative is a resonator. Cost is like 65 at a muffler shop (that price included to have it welded on for me)
Old Dec 15, 2008 | 09:34 AM
D4u2s0t's Avatar
sigh... you don't want backpressure. i don't know why so many people think they want backpressure.
Old Dec 15, 2008 | 01:06 PM
car_guy_09's Avatar
Is this directed towards me?
Im a turbo guy, And with them backpressure is never even a thought. But with N/A and supercharged motors everybody always say you will loss power with a cutout,
I have done some research on backpressure but its been awhile, IIRC, Its not realy backpressure that is good, its the "scavenging" or what ever its called that you want which goes along with backpressure.
And my car just has an intake so its not 400hp flowing a **** ton of exhaust lol
Old Dec 15, 2008 | 01:10 PM
ShortStack's Avatar
yes, yes it was.
Notice how i said, you would have make yourself look stupid (i meant by posting another backpressure thread)
i did not say that you WERE stupid...
Last edited by ShortStack; Dec 15, 2008 at 01:10 PM. Reason: Automerged Doublepost
Old Dec 15, 2008 | 01:13 PM
car_guy_09's Avatar
Well when it comes to this car i am stupid at times so its good...
Like i said all my know how and experience comes from turbo cars, So this is a whole new concept to me.
The only reason i wanted a cutout is so i could keep stock catback so its still quiet
Old Dec 15, 2008 | 01:14 PM
D4u2s0t's Avatar
scavenging and backpressure are 2 different things. backpressure is air going the wrong way through your exhaust. scavenging happens when a vacuum is created in the exhaust which helps pull the air out, letting the engine work more efficiently. scavenging is not something you want TOO much of though.
but backpressure is not good, regardless of na, turbo, or super.
the biggest thing you want is exhaust VELOCITY. you want to get the exhaust out as quickly as possible to make room for the new exhaust. go too big, and the exhaust pulses will run into each other, which in turn makes the engine work harder to push them out. go too small and again the engine has to work harder to force the air out. this is why exhaust size is an important thought. most people just slap on an exhaust and call it a day, because they want a loud car. aka ricers.
Old Dec 15, 2008 | 01:20 PM
car_guy_09's Avatar
Thats exactly what i dont want, Im trying to keep it as quiet as possible.
Old Dec 15, 2008 | 02:48 PM
PhantomSS's Avatar
http://www.youtube.com/watch?v=pV1mxz3Svjo
then your like me.
i dont know of many other's short of people buying hahn systems that sound as good as mine.
gmpp exhaust with 2 reversed glasspacks.
Old Dec 15, 2008 | 02:50 PM
car_guy_09's Avatar
Does sound good....
Old Dec 15, 2008 | 02:51 PM
PhantomSS's Avatar
actually listen to the hahn flyby after it goes past the camera man it sounds kinda like a honda. Not comparing it to hahn 3 inch, but my standards for exhaust is very high.
