Exhaust system
Old Feb 8, 2012 | 04:02 PM
Tony Pshenichnykh's Avatar
Exhaust system
I'm new to this tuning stuff so I'm I'm trying to set up badmad header, zzp 2.5" dp, 2.5" cat-back. On zzp website there are bunch of options so for dp i was told to get high flow cat and I'm not sure what to pick for cat-back. It says no downpipe flange (weld-in), Bolts up to 2.5" downpipe flange, and Bolts up to 3.0" downpipe flange. So which one do i need for my zzp cat-back?
Old Feb 8, 2012 | 04:09 PM
06cobalt racer's Avatar
I would get the 3 inch downpipe with a 2.5 inch exit. Then get the 2.5 inch bolt on cat back.
07LSJ's Avatar
depends on your power goals. letting us know what car you have would help as well, even though im guessing lsj.
up to around 255whp your good with 2.5" anything after that most tuners would recommend 3" all the way.
Old Feb 8, 2012 | 04:10 PM
SKCobalt's Avatar
I would say that you'd be looking for the downpipe with the 2.5" flange. You just need to make sure that the DP flange matches the catback flange. If you already have the cat-back, you need at dp with the 2.5" flange. If you already have the dp, make sure that the flange is 2.5" which it should be because it is a 2.5" dp.
Hope this helps.
Old Feb 8, 2012 | 04:31 PM
I got 06 SC/SS, so 2.5" dp high flow cat and cat-back w/ Bolts up to 2.5" downpipe flange?
Old Feb 8, 2012 | 04:35 PM
But isn't the BadMad header 3"? So should i be getting 3" dp?
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
