F35 Trans Rebuild or Replace
Old Jun 25, 2023 | 06:24 PM
chris88z24's Avatar
Need to either rebuild or replace the trans in a 2007 SS/SC. It has the LSD.
Does anyone know if Powell rebuilds these transmissions? I remember he possibly did back in the day but I can’t remember 100%.
Also if anyone knows where you can buy a new replacement trans with LSD that’d be helpful too.
Thanks in advance! And yes, this is my old car. It’s still in good shape!
Old Jun 25, 2023 | 08:49 PM
southal cobalt's Avatar
At this point, it seems like people are rebuilding, doing an f40 swap, or a 2.2 swap. The last few new transmissions popped up on crate engine depot about 2 years ago. I’ll be surprised if anymore are found
Old Jun 25, 2023 | 10:53 PM
Eagle_f90's Avatar
New does not exist anymore and last i checked (ealry last year) powell is out of the game and no way to get agold of him. If you can find a good used f35 without the lsd you ca juse it as a donnar for the parts
Old Jun 25, 2023 | 11:23 PM
chris88z24's Avatar
How are people rebuilding? Don’t you need special tools?
This one, the gears and everything are fine but it looks like the carrier bearing for the diff is bad. Not sure if that can be replaced without special tools etc.
Old Jun 26, 2023 | 02:15 PM
michael23v's Avatar
I just got an F35 with 4.45 gears from powell. Just had it shipped last month and will be installing soon.
Old Jun 26, 2023 | 04:38 PM
chris88z24's Avatar
Do you have his contact info? I checked Google but didn’t see any info for his shop or anything.
Old Jun 27, 2023 | 12:25 PM
michael23v's Avatar
I sent you a PM.
Old Jun 27, 2023 | 03:38 PM
chris88z24's Avatar
I sent you a PM.
Tried emailing Gloria but the email comes back as undeliverable.
Old Jun 27, 2023 | 03:40 PM
michael23v's Avatar
I think i sent the wrong one.
Old Jun 27, 2023 | 04:16 PM
Eagle_f90's Avatar
Do you mind sending her contact over to me? I have some of there prosuct i have questions on and want to see if they still make somethibg. I had there infor and was chating with her oncw but then it started bouncing and cant get back in touch
Old Jun 28, 2023 | 09:12 AM
fake_judas's Avatar
If I can butt in with some f40 questions, does anyone know about the different axle I'm suppose to use? I'm looking to order the zzp conversion kit and adding one axle jumps the price 800 dollars. There has to be other options right?
Also I just installed a new clutch master clutch and new flywheel before the f35 died. I'm going to assume neither of those will work now.
Old Oct 8, 2023 | 12:19 PM
RemoDellucci's Avatar
Non sono sicuro... alcuni produttori o fornitori di trasmissioni aftermarket potrebbero offrire trasmissioni compatibili con LSD per la tua auto. Quando si considerano le opzioni di ricambio, è importante verificare la compatibilità e l'affidabilità. Personalmente, mi concentro di più sui giochi d'azzardo con prelievo rapido e potrei consigliarti di consultare https://gamblingorb-it.com/casino-on...elievo-rapido/ per cercare tali casinò . Inoltre, puoi esplorare i depositi di rottami o i riciclatori di auto per trasmissioni usate con LSD. Questa potrebbe essere un'opzione più economica, ma richiede una rigorosa verifica delle condizioni della parte usata.
Old Oct 11, 2023 | 12:44 PM
tomj77's Avatar
Powells email changed which is why no one can get a hold of him
Dave8699
Nov 12, 2017 10:19 PM
advise
Jul 29, 2013 12:57 PM
hucks1987
Oct 22, 2012 02:05 PM
PrincessTurbo
Mar 25, 2011 08:00 PM
mongorat427
Mar 20, 2011 07:38 AM
