First 300 BHP Cobalt soon ...
Here is some images ... see the link in the Member's gallery !
- Custom 2,5" catback with Magnaflow muffler
- Pulley Technology 3,0" pulley
- Cold Fusion Nitrous Wet Kit (uninstalled)
- Fujita Competition Cold Air Intake System (uninstalled)
- SCdyne Header (uninstalled)
https://www.cobaltss.net/gallery/bro...=3&userid=2736
Installation of the CAI and Header (and dyno results) will be this very friday.
Have a nice day !
Have a nice day !
hmm 300 as already been passed by a few people
Just wait till after SEMA
but those mods seem to be a great combo and i can see alot of people heading in this direction very soon behind you.
congrats
congrats
Originally Posted by zinner
Good luck man. Is that a wet or dry shot nitrous system?
Originally Posted by victory_red_SS
let us know how the install goes and how the header lines up
haha my thoughts exactly...
hey jmc007, did they finally start sending out the proper gaskets with the header? i know he tried telling people for a while the stock gasket would work, then he took a few months or something to get the correct gasket to people.
i wish you the best of luck with that header, because so many people had problems with it on the saturforums. especially the guy that had to take it to a local machine shop and have the surfaces refinished
Have a nice day !
Have a nice day !
Where is the N20 Nozzle located? You do know that spraying N20 through the eaton ruin's the rotor blades
I have talked to ZEX and NX and they both say it is fine to run before the blower. They also said you should go wet with forced induction. I have seen big v8 cars with the big blowers that have the carbs mounted on the top of those run nitrous from the carbs. That would mean that the nitrous runs through the blower.
Different kind of blower.
I have read that the Nitrous will degrade the coating on the rotor's leaving them prone to failure in the future.
people are gonna do what they're gonna do. but that's why i stopped using my water injection. i didn't want to mess up the blades.. even though some were saying it's fine to do it, i got to thinking that mist of water after a while will probably screw something up. now i'm on mission "find an adapter plate that will fit underneath the blower so when i get a smaller pulley it will fit there fine and have a nozzle spot for my w/i "
yes it's a long mission name but it's worth the effort
have you thought about taping into the intercooler below the S/C i have the snow performance kit and it was installed on another car before the blower and i ran into the same problem which started to eat the teflon off the rotors.
the best i can figure is to tap into the intercooler and inject from there
nah honestly the adapter plate is going to be the best way. think about this, i want to do alkie/water injection and i want a smaller pulley. by putting a smaller pulley on, it's going to give alot os slack in the belt, by paying $100 or whatever to have a plate made that fits under the blower, with a place for my nozzle. that will also raise the blower back up a bit, which in turn will keep the belt tension on and will keep me form buying a belt tensioner, end the end from the money i save on a tensioner, the adapter plate will have cost me about $20
that makes good sense
here is a link to a post on the local(to me) gtp board - http://www.azclubgp.com/viewtopic.php?t=3045
this guy actually just tried to clean his up , and ended up taking the coating off the rotors , the fuel will do the same thing
alot of people have been using alky injection on our style s/c's with no problems , or coating issues
same thing goes with using a dry shot of nitrous , the only bad side is the nitrous can cause you to lean out , so you need to be on the higher end of the rich scale , to help prevent problems
our s/c are made differently than the draw through style s/c's with carb's or injection above them
I'm going to try to get a Water injection soon. I more or less have a machine shop in my garage so i'll see if i can make a plate out of alunimum(sp?) for the injector. If any one is interested i can prob. make a couple extra. Just an idea.
