Flowthrough Tank for track??
Old Mar 17, 2015 | 10:13 PM
volsfan92's Avatar
I'm gonna try to make a flowthrough that will add more coolant to system..I've found the stu mod but I cant find a hose diagram for stock endplate with zzp h/e...Does anybody know how to route hoses correctly?
Old Mar 17, 2015 | 10:43 PM
ItalianJoe1's Avatar
Use the hoses coming up to the stock filler neck. One going into the tank, one coming out of it.
Old Mar 17, 2015 | 10:46 PM
volsfan92's Avatar
I know but doesn't one need to go in tank higher than the other ?
Old Mar 17, 2015 | 10:47 PM
Link to stus setup pls?
Old Mar 17, 2015 | 10:52 PM
volsfan92's Avatar
This is original I think I jus can't find clear instructions in it..https://www.cobaltss.net/forums/2-0l...ox-mod-166658/
Old Mar 18, 2015 | 07:12 AM
mrbelvedere's Avatar
stu never posted directions
Old Mar 18, 2015 | 08:58 AM
jcobaltss's Avatar
I run a flow through its the same as having the stock filler neck just get longer hose and use the diagram that shows stock filler neck with added heat exchanger.
Old Mar 18, 2015 | 10:00 AM
volsfan92's Avatar
Ok thanks everyone for the help.. Doesn't one hose go higher on tank than other?
Old Mar 18, 2015 | 10:04 AM
jcobaltss's Avatar
Yeah I believe the one coming from the pump goes up top but I can double check when I get home if you want
Old Mar 18, 2015 | 10:39 AM
volsfan92's Avatar
Ok that's good thanks man
Old Mar 24, 2015 | 11:31 AM
Viperoni's Avatar
I've been thinking about doing a fabricated tank where the Option B goes... it would take up the entire side pocket where the current Option B tank goes, probably doubling or tripling the volume that the Option B adds.
I just did a winter lapping session @ Toronto Motorsports Park this weekend, and with ~32f IAT1, I was pushing ~155f IAT2. Not good. Bone stock SC and IC systems though, so I'm expecting a noticeable difference when I do the dual pass and Option B/fabbed tank.
Old Mar 25, 2015 | 10:06 AM
advise's Avatar
like mine
Old Mar 25, 2015 | 10:40 AM
Staged07SS's Avatar
Administrator
Administrator
So many people miss the actual point of Opt b....
It isnt there to add coolant volume. It is there to provide a constant bleed of the intercooling system which is very important to a properly working system.
Opt B, dual pass, Griffin.... all track tested, and work wonders.
Flow throughs can be nice if done right, but are really not "needed".
Thats your problem right there if tracking the car.
Old Mar 26, 2015 | 10:26 AM
Viperoni's Avatar
I know that my particular issue is that I haven't done the Option B and Dual Pass, but I'm pretty sure a bigger Option B tank would help.... Mr.B always raves about increasing the volume of the intercooling system and incrasing the thermal capacity of the system just seems to make sense..... now would it be worth the cost of the filter neck and sheet metal? Hopefully lol.
Old Mar 26, 2015 | 12:22 PM
Staged07SS's Avatar
Administrator
Administrator
Good luck in your quest sir!!
Nothing wrong with trying things out.
Old Mar 29, 2015 | 11:50 PM
volsfan92's Avatar
I made this!
Old Mar 30, 2015 | 01:04 AM
06cobalt racer's Avatar
I made this!
Old Mar 31, 2015 | 10:31 PM
volsfan92's Avatar
Originally Posted by 06cobalt racer
Thanks for the help I was able to go with this big reservoir..helps so much with recovery and heat during pulls
Old Apr 1, 2015 | 12:43 AM
The only issue i see with increased volume is that eventually your fluid will still reach a certain temperature, especially if the majority of that fluid is not in a aircooled core. Instead its flowing through a tank inside a hot engine bay, granted adding ice is nice but how often do you want to drain that and keep ice in it?
Old Apr 1, 2015 | 01:15 AM
no problem man. glad i could help.
to my understanding the benefit is to delay the rise of the temps. the more fluid there is the longer it takes for it all to get heated up.
Old Apr 3, 2015 | 12:01 PM
WVU_SS's Avatar
True it takes longer, but you need to think about the bigger picture. Doubling the volume will essentially double the time it takes the fluid to have the same temperature rise. That tank appears to have maybe double the volume of traditional option B, which is a very marginal volume gain in terms of the complete system. A more effective approach would be to rig up a way to pass the coolant through a heat exhanger to remove heat from the system. This would be more efficient than adding fluid imo.
Old Apr 3, 2015 | 08:20 PM
southal cobalt's Avatar
yes, this tank may be twice the size of option b, but the fluid in the overflow tank with option b does not flow through the system, unless you lose fluid. its an overflow tank. it has one line out and no lines back in.
therefore going to a flowthru design will increase the amount of useable fluid, because it actually flows whats in the tank. so if your tank is double the size of the overflow tank, then you are actually increasing the fluid capacity by more than a factor of 2 compared to opt b
Old Apr 3, 2015 | 11:51 PM
thats effectively what you are doing by adding on a heat exchanger like a griffen.
Old Apr 6, 2015 | 07:16 AM
Staged07SS's Avatar
Administrator
Administrator
Ill say this again..... Opt b is not there to add coolant to the system!!!!!
Stop comparing flow through tanks to opt b.
Old Apr 6, 2015 | 09:14 AM
you are wrong fluid constantly flows through the option b tank. fluid comes out the top of heat exchanger into the tank then out the bottom of the tank back into the system
it could not constantly bleed the system if coolant did not flow through it
adding volume helps but just adding an extra quart wont do that much
