fried my pcm
Old Mar 6, 2007 | 09:55 PM
spaz's Avatar
fried my pcm
Any Ideas, I was programming my pcm with hp tuners and now it won't communicate anymore. The pcm won't turn on the cel when I create codes.The only scan tool that communicates with the pcm is the aeroforce gauge.
Old Mar 6, 2007 | 09:56 PM
Shortbus's Avatar
Get a new one, does the car still start and all that?
NightriderCobaltSS's Avatar
does the car still start ?
Old Mar 6, 2007 | 10:01 PM
Ljavy17's Avatar
dude WTF! thats exactly what happened to me today. My hPtuners cannot connect to the pcm. and if I try to connect with the VCM scanner it says the vcm cant be located. and it throws a little LOCK thingy code. is that happening to you too?
Old Mar 6, 2007 | 10:03 PM
Darksun's Avatar
Don't quote me on this but I believe our PCMs have a certain amount of times they can be flashed before they go kaput! I doubt any of you guys have reached that point but I would say around 100+ would put you in the odds of it happening.
Old Mar 6, 2007 | 10:05 PM
Ljavy17's Avatar
really? I dont think ive reflashed that many times. However, does it require a certain amount of times before it gets unloked. Its almost like my pcm is locked.
Old Mar 6, 2007 | 10:06 PM
06blackg85ss's Avatar
phil you are wrong my friend... flashed mine now close to 200 times.. still going strong..
reset the battery... and try to get it to scan again.. good chance you might have reflashed a different VIN # onto the car... I did that the first time I flashed mycar... but fixed it
somehow
Old Mar 6, 2007 | 10:09 PM
Ljavy17's Avatar
the only way to change the vin of your car is if you use 2 credits and do a write entire. Both of which I didnt do............
Old Mar 6, 2007 | 10:11 PM
spaz's Avatar
NO where near 100 flashes. It acts like it is not plugged in . it says interface found but no vehical power detected.
The car runs but it is in limp mode with no check engine light.
Old Mar 6, 2007 | 10:12 PM
dunno... mines still going strong... I thought my pcm was fried, just ended up being a fucked up super charger
so it runs in engine PWR reduced
migtha blown the fuse to the OBD II port
Darksun's Avatar
somehow
Im waiting to see by end or summer how it goes. Im sure some redline guy has the stats on the PCM. But paul you got to admitt GM didnt plan on the avg joe having his own way to flash the PCM a million times over
did you reset by disconnecting the battery
Old Mar 6, 2007 | 10:14 PM
nope that the cig light fuse and shouldnt casue a Limp Mode i knwo that one
Old Mar 6, 2007 | 10:15 PM
i don't think planned on someone like me doing what I do to the poor poor car... lol
thats was just for the power error you were getting.. nothing to do with the limp mode..
have you added any electronic components lately?
Last edited by 06blackg85ss; Mar 6, 2007 at 10:15 PM. Reason: Automerged Doublepost
Old Mar 6, 2007 | 10:18 PM
Doc's Avatar
Doc
I've flash my car over 200 times....its still going strong.
not sure about the CEL...but were you logging the car? Playing a log back? Have the Scanner open or just connected? If you did, close them and the scanner and try again.
Old Mar 6, 2007 | 10:22 PM
Darksun's Avatar
Well I still think its a possibility but I doubt its the Problem in this thread.
Old Mar 6, 2007 | 10:23 PM
spaz's Avatar
I am sure it is the pcm.I can unplug sensors and it doesn't set the cel it does set codes I can read with my aeroforce gauge but the hptuner scaner or vcm editor don't comunicate.I tried them on my truck and it seems to work fine.
Old Mar 6, 2007 | 10:26 PM
Doc's Avatar
Doc
what codes are coming up..?? something about communicating with the BCM..?
check your battery in your laptop too...
Old Mar 6, 2007 | 10:38 PM
zinner's Avatar
Moderator Alumni
The aeroforce gauge doesn't use the OBDII power. The MPVI does. Have you checked the fuse. If you are in limp mode there is a code set what is it?
Did you flash it and it went hay wire?
If you want help you need to be clear on how you got to the situation your in.
Old Mar 6, 2007 | 10:44 PM
spaz's Avatar
I checked the connector it has power on the pin 16 and ground on pin 4
Thats all I can think of I guess tomorrow I will price out a new pcm.
Old Mar 6, 2007 | 10:58 PM
Ljavy17's Avatar
Okay I have the same problem as him. however my car works fine. I was tunning my friends car and all of the sudden we tried to flash it and it did not work. It did not connect. then the car would not turn on, we waited a while and then the car started! so we drove to my house and checked the hptuners on my car and it did not work. It did not connect either. I didnt try to rewrite my car but tried using the vcm scanner, When I tried to connect the vcm scanner, (like when I pressed play) it made a weir bell sound, and then it showed the icon thats an orange lock with a car on the side. This same icon goes on when you lock your car with you keyless remote.
Old Mar 6, 2007 | 10:59 PM
Lithium's Avatar
Its an error in the latest HP tuners update. My Tuner had to get ahold of HP Tuners to get it fixed.
Old Mar 6, 2007 | 11:03 PM
SStud's Avatar
sorry to hear that, Rock auto.com is a good place to look for parts (New PCM) if it comes down to it.
