Front mount HE install question
Just got mine in from CA and I have a few questions before I start the install.
1-What is everybody doing when they're installing the new heat exchanger, keeping the stock one on and using it as well or taking it off completely?
2-Does anybody have any pictures or directions on how to install it keeping the stock one?
3-Will I have to bleed any air out after I install it, and how is that done?
THANKS FOR YOUR TIME
1- when i installed mine on my old balt i kept the stocker on, but ran the lines so it still passed threw both, but i have heard and done some searching that it would be better to take the stocker off and just get a dual pass end plate.
2-i have a picture i made in ms paint that may help, its pretty straight foward i believe there is a write up.
3- during install you will drain and bleed it out when you take the stock lines off, and then when everything is back and installed you will have to keep adding and watching it maming sure it doesnt go down or you dont have any leaks.
