Fuel filter
Old Mar 25, 2007 | 01:04 AM
ItalianJoe1's Avatar
Originally Posted by mken
(on a side note, it looked like someone rolled a joint in that catch can after the fuel drained into it, car starts right up now and idles nice and smooth, huge difference!)
How many miles do you have on the car?? I am just wondering how bad mine will look. I think sometimes I get inconsistent fuel pressure, and if you had that happen then it makes sense.
Old Mar 25, 2007 | 08:15 AM
mken's Avatar
I have just under 34,000 miles. Took my car in to the dealer twice because it would never start on the first try when the engine was cold, but they said they couldn't "duplicate the problem". Also, the idle was real bouncy, sometimes stalling while I was waiting at lights. And even though my tail pipe was turning my bumper black, I also kept getting the lean code (and couple times a P0300 (random misfire)). Haven't driven it much since I changed the filter yesterday, but so far the issues seem to have gone away. I feel like an idiot for not already replacing the filter, and wonder why the dealer didn't check it when I brought it it (they even suggested that it sounded like I had a problem with fuel pressure).
Old Mar 25, 2007 | 09:49 AM
cool, I have about 28000 on mine, so I guess it needs to be changed. I'll change it real soon.
Old Mar 26, 2007 | 05:45 PM
badboylb32's Avatar
sorry for this noob question but for some reason i dont know. all i have to do to release the gas pressure is take the gas cap off right?
Old Mar 26, 2007 | 08:18 PM
rnjmur's Avatar
To relieve the fuel pressure you must remove the fuel pump relay then start the car. I have submitted a how-to on changing the fuel filter, but the mods have not or will not approve it for some reason...
Old Mar 27, 2007 | 01:12 AM
badboylb32's Avatar
yep thats what i did. changed it out tonight. also put on my gm honed exhaust manifold. wow what a big diff with both of those. ****** peeled for like 2 secs in 2nd gear 2wice with just gm touring exh, gm exh manifold, and injen cai and ingalls.
Old Mar 27, 2007 | 01:27 AM
phxSS's Avatar
Where's the pump relay? Is it next to the "battery" in the front? In ther large black box?
Old Mar 27, 2007 | 06:17 AM
Red07SSNA's Avatar
The "battery" you are referring to is the fuse box (Battery is in the trunk).
According to the factory service manual you only have to relieve the tank pressure by loosening the fuel fill cap -- and expect some fuel spillage when you disconnect the filter lines -- no need to run the car with the fuel pump relay pulled to remove pressure from the lines.
If you really have that much junk in your filter with low mileage you need to take your car in for the dealer to look at replacing your gas tank. If it is fine rust particles it will only get worse.
Old May 28, 2007 | 06:35 PM
silverSS's Avatar
i just changed mine at 26k and it feels so much smoother throughout the powerband. worth the $40 it cost me total!
i recommend all you stg guys who are getting that choppy acceleration to do this if you havent.
Old May 28, 2007 | 10:50 PM
RBC's Avatar
RBC
Anyone have a part number?
Old May 28, 2007 | 11:52 PM
  #36
silverSS's Avatar
go to ced, they have it under maintence i believe
Old May 29, 2007 | 12:04 AM
  #37
TxLonghorn#1's Avatar
Here goes the link for the poeple that wanted a part #. It's from AC Delco:
http://198.208.187.182/internet/Vehi...e=22&part=6200
Good luck
Old May 29, 2007 | 01:15 AM
  #38
RBC's Avatar
RBC
www.gmpartsdirect.com has it $30.90. part #22734980
Old May 29, 2007 | 02:00 AM
  #39
silverSS's Avatar
make it happpennn
Old May 29, 2007 | 10:09 PM
  #40
RBC's Avatar
RBC
Originally Posted by silverSS
make it happpennn
I just did!
Old May 29, 2007 | 11:06 PM
  #41
silverSS's Avatar
Originally Posted by aeballa6
ehh u work for jiffy lube? do yall scam people liek the other ones do?
lmao i know right!
like hes bragging he works for that company, i would be ashamed.
flame on
peace
Old May 29, 2007 | 11:28 PM
  #42
RBC's Avatar
RBC
Sorry to get off the topic at hand, but 06noscobaltss what does the dirt on the outside of the filter have to do with how clean or clogged the inside is?
no_ss
Oct 18, 2015 11:58 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
