Fuel Filter
www.crateenginedepot.com they've got the OEM fuel filters and oil filters you should use on our cobalts.
forgot to say, you'll probably be paying about $40 for a fuel filter, thankfully i found the part number and found someone on ebay selling dealer inventory and the exact filter needed for $10. Gmpartsdirect.com and gmpartscheap.com will have them too.
yeah, the fuel filter was actually the easiest thing i replaced on the Cobalt, easier than the oil filter. Besides having to jack up the car you take out one bolt, then there are 3 quick disconnect fuel lines, one you need a special tool for. Whole filter change time was about 10 minutes after getting my car set up on ramps.
most cars they say 30000 miles. but it never hurts to change it early
most times they suggest fuel system service at 30000 which includes the fuel filter, but like said above it depends
Last edited by BOOSSTED 06; Mar 11, 2008 at 12:52 PM. Reason: Automerged Doublepost
wow thats nuts. Wix doesnt even offer a filter for our cars. I guess will have to stick to the OEM. are there any special procedures to R&R this filter? such as clamping anything to keep gas from spraying everywheres? thanks.
cool thanks. spraying was just an over exageration. spraying did however happen when i replaced the injectors, and this is not an exageration lol....now this fuse you speak of, is it located under the hood or under the dash? thanks again
ahaha good to know. appreciate it fellas. i have to replace my spark plugs too now/again. i tried the E3s and they were good for 15k. put my original coppers back in and they are apparently at the end of thier life span as well. damnit. so i am thinking of going with the iridium xtreme ngks. woohoo...mucho expensive
I replaced mine at 12K miles and when i blew it out backwards their was a ton of brown **** in it . I only run sunoco 93 (94 isn't around here anymore) . I was amazed that it was so dirty @12K , i ended up changing gas stations to see if it helps at all.
I have put 12k on my car since I put stage 2 on and I changed my plugs and fuel filter last weekend and from lookin at my plugs it looked like I was running just a touch rich but not too bad and I changed my fuel filter and it was pretty clogged...there is a good how-to on changing your fuel filter on the how to thread
oh nice. yeah i am amazed too. we all use premium, i mean its suggested when we upgrade to stage 2. none the less, my tail pipe is still super black. i dont get it, i thought higher octane burned cleaner. i have 45k on my car and havent changed the fuel filter yet. my dad works for GM so he is picking me one up this week. so i will have it changed soon. still just seems wierd to me all the carbon build up we get in these cars running on premium. i use BP 93 every time.
