fuel line bleeding ?
Old Jul 2, 2009 | 08:10 PM
gearhead06's Avatar
I know when you put new fuel injectors in your supposed to bleed your fuel line now if I ordered a ottp stage kit and they already flashed my computer is it ok to plug the pcm back in to start it up just to bleed the fuel line pressure down?
how important is it to bleeding the line to put new injectors in?
Old Jul 2, 2009 | 08:12 PM
BLAZIN07SS's Avatar
I'm too JDM for you
just get a rag and a flathead. remove the fuel rail cover. remove black cap on the schrader valve. layer the rag over that valve and press down with the flathead. keep doing that until all the pressure is out of the rail
Old Jul 2, 2009 | 08:18 PM
gearhead06's Avatar
o ok that works than, the gm book tells you to pull the fuel pump relay and start it up to it stumbles
Old Jul 2, 2009 | 08:20 PM
BLAZIN07SS's Avatar
I'm too JDM for you
that works too. just takes a lot longer
Old Jul 2, 2009 | 09:36 PM
Jn2's Avatar
Jn2
the fuse box method, pull the relay, turn it on, let it die...now all ur lines r empty
Old Jul 2, 2009 | 09:54 PM
thc's Avatar
thc
x2.. do it all the time when i put the race gas in the car
Old Jul 2, 2009 | 10:19 PM
gearhead06's Avatar
I ordered a ottp stage kit and they already flashed my computer is it ok to plug the pcm back in to start it up just to bleed the fuel line pressure down on my stock components
Old Jul 2, 2009 | 11:43 PM
Johnboy12358's Avatar
I would think if all you are doing is idling till it dies, i would be ok, but dont take that as gospel, I really dont know for sure
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
SlowSaturn
Sep 28, 2015 11:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
