Full Boost No Power!
Like it says @ full boost I have slow acceleraton also no blower whine (kind of a engine bogging down sound instead) doesn't get above 3k very fast..
then sometimes some power will kick in and i get some good acceleration...
other times not so much...it's got me stumped...
also sometimes hard starts and sometimes soft starts...
Really at a loss here...
Replaced the Evap purge valve silanoid. - was thinking it would fix the hard/soft starts - it didn't.
Fuel filter replaced about 9k ago...
Plugs changed about 9k ago...
Car is 100% stock...change filter about 6k ago..
Cleaned MAF @ same time..
TB cleaned same time..
Belt has been replaced about 6k ago..
Alternator replaced about 9k ago..
Idle is pretty smooth..
Throws no codes..
Could a bad map cause this?
80,000 miles.
Throws no codes..
80,000 miles.
That's what i've been wondering...
I don't boost higher then I should though, and the cat doesn't glow..
I took it to a place that does free cat checks with a sniffer..but said they wouldn't
do it cause my check engine light wasn't on...blah..
yup the maf is tight
was doing it before I ever removed it also.
It straighted up for a little while and ran fine...then went back to this..
It straighted up right after a seafoam through the vac...was good for 3 weeks, then started it up one day and it was doing it again.
Well the cat did blow out at 20k...according to the lookup on it...that was way before I got it.
I got it at 62k.
Is it ok to clean the inside of the map out with electronics cleaner?
I got it at 62k.
