Future Mods
Future Mods
for the winter.. i will only have a CAI and a HP tune by Denny..
during winter i will order stuff and install it in the Spring
mods in mind
Stage 4
60# Siemies Injector
Autolite Cooler Plugs
2.6" ZZP Pulley
Wiring Harness
ZZP Belt Tensioner
Supercharger Ported
TB Bigger and Ported
Hahn Headers and Downpipe. ( With or Without Cat..? )
Hahn 3" Cat-Back or Magnaflow Cat-Back
Lots of thing for less wheel hop
Tractiob Bars, stiffer mounts,
any other recommendation..?
Thanks
mods in mind
Stage 4
2.6" ZZP Pulley
Wiring Harness
ZZP Belt Tensioner
Supercharger Ported
Thanks
Cooling mods cooling mods cooling mods man.
First off, screw that canned tune and those crazy undersized pulleys over spinning the blower. Here's a list...
60# Injector w/ Wiring Harness
Nate hub and pulley system w/ 2.8" pulley
Stage 2 Belt (plus oversized Tensioner if needed. Likely not)
A good Header/Downpipe/Catback in 2.5", with a high flow cat
Dual Pass endplate w/ Option "B"
Cobra Heat Exchanger *or* LFP Heat Exchanger, run in line with the original
TTR Solid Motor Mount and Tranny Mounts
Intense CAB
Strut Tower Bar
Rear Sway Bar
Struts and Springs *or* coilovers
Slotted Brake Rotors
Better Brake Pads
Steel Brake Lines
And finally, a crazy custom tune done by a good tuner instead of some canned tune junk.
If you got the big money, a couple of other ideas...
Head ported, honed, and polished for maximum airflow
" If your going to get crazy head work done and want 300+whp, then you can consider a 3" exhaust
High performance valvetrain that supports 0.5" lift/8k+ rpm (Don't run it that high man! Thats for safety)
Custom ground cams with ~0.5" lift
Forged Pistons
Intense CAB
Strut Tower Bar
Rear Sway Bar
Better Brake Pads
Steel Brake Lines
Forged Pistons
Intense CAB
Strut Tower Bar
Rear Sway Bar
Better Brake Pads
Steel Brake Lines
Forged Pistons
Intense CAB
Strut Tower Bar
Rear Sway Bar
Better Brake Pads
Steel Brake Lines
Forged Pistons
dude i love the in-car microwave idea
whats the Intense CAB..?
for the mounts i already have a Ingalls Engine Damper.. so putting Solid mounts will be like if i ordered my Damper for nothing
for the Meth kit i'll ask denny to hook me up
where can someone find a place to get the car tuned once the mods are in place? Thats whats holding me back. Is the car safe to drive to the place it will be getting tuned or should the mods he installed at the same place as the tune
Typed on my Iphone.
Typed on my Iphone.
Last edited by Immortal Technique; Oct 14, 2007 at 01:10 AM. Reason: Automerged Doublepost
I agree with the 2.8" pulley to keep the supercharger in its efficiency range. Also, i've heard traction bars are mainly for drag racing use. If you'd like a daily driver with good cornering abilities, i would probably recommend tranny mounts and/or CAB's instead.
Your injectors would not be safe at all without a tune, since they will be dumping about twice the fuel the stockers do.
Best thing you can do is go to your reginal section and start asking around to see if anyone has HP Tuners around where you are located.
are the solid mount really solid..?
in Bwoody they say "Our best value a full set of solid motor mounts for 2004-2007 redlines, energy suspension bushings and all hardware is included"
Energy Bushing.. those go in the mount right...?
so those will give me less wheel hop from my LSD.. since i have my Ingalls Damper Set to almost the max i can go and i have little wheel hop..
Thanks
an0malous
my oncle should be doing around 13.2 with his car.. on 4 season falken tires
i did 13.7 /109mph at 10*C on the falken on a crappy drag strip.. and if i went to Napi or Sanair.. and also been retuned by denny.. i must be hitting 13.2-13.3 with his car now.. but mine is stock for now
Thanks
an0malous
for the intense CAB.. where can i get those..?
i ordered the BWoody Complet Solid Mount Set for engine and tranny.. i also have my Damper.. ordered some other stuff.. injector pulley..
next is the exhaust.. after that.. the front mount intercooler and dual pass plate..and water/meth.. i'll try to get hooked up by denny..
and i sold the RX-7
and i sold the RX-7
those CAB are pretty expensive lol
mods in mind
Stage 4
2.6" ZZP Pulley
Wiring Harness
ZZP Belt Tensioner
Supercharger Ported
Thanks
mods in mind
Stage 4
2.6" ZZP Pulley
Wiring Harness
ZZP Belt Tensioner
Supercharger Ported
Thanks
def get water meth and a dual pass
and im sure you know youll need a good tune gooluck
