Gaskets Question
Gaskets Question
Hello,
When removing/installeing the supercharger and doing a dual pass endplate.
What gaskets are all needed? I have the intake manifold gasket and the supercharger gasket and the one for the throttle body. But the super charger gasket doesnt cover the bypass portion of it. What gasket do I need there? Or do I just RTV that?
What about the dual pass end plate? Does that get a gasket? or RTV?
What if I use the ZZP Pheonalic spacer on the super charger? Does it go under or on top of the gasket?
you only need an intake gasket
the supercharger, end plate, bypass and tb are all reusable(tb can stay on unless you wanna take it off)
if you use the phenolic spacer it goes between the head and manifold
comes with all hardware spacers and gaskets
pm me for any other info did the whole job last winter
Sep 28, 2015 12:51 PM
