Gear ratios REDLINE vs SS
Originally Posted by vandy0419
Actually the 17s aren't light at all...anyone know how much the 18s weigh vs the 17s? You have to remember your 18s are cast and the 17s are forged wheels so I'm not sure if it makes much of a difference.
I have no Idea about the Red line.
Originally Posted by player_1
wrong our 18" are forged aluminum, which is part of the reason they are so light. approx 21-22lb the factory Perelli's are 23-24lbs.
No they are cast
the recaros and forged wheels on even the base redlines were like consolation gifts for buying the saturn
Originally Posted by djt81185
redline uses 215/45/17
cobalt uses 215/45/18...therefore cobalt tires are 1" larger overall giving them a lower effective gear ratio
Originally Posted by Tomtwtwtw
That would make a difference, but only about 1% worth. (811 revs/mile for the Cobalt tires vs. 821 for the Redline) Maybe the speedo is off, or he's just spinning in 2nd?
Oh come on...its not an INCH DIFFERENCE!!! In diameter yeah, but the wheel (not including tire thickness) on a RL has a diameter of 226.86" while the Cobalt SS is 254.34"
d=Pi x (r x r) <~~can't get the squared symbol but same thing!
So every one revolution of the cobalt, it travels an extra 28" than it does on a RL...but don't forget the cobalt and RL have different VSS (variable speed sensor) calculations.
Originally Posted by hatrickstu
yes it is an inch difference do the simple math man a 215/45/18 tire is about 25.6 inches in overall diameter, a 215/45/17 is about 24.6 inches in diameter. my gosh people
hatrickstu, do you not read a full post?
same width plus same aspect ratio means same tire sidewall height...17" vs 18" 1 inch difference omgwtfbbq 1" diff in diameter.they are different and it is enuf to effect it
told u common sense is lacking lol
I said yes it is in diameter but the actual amount of travel is completely different for each revolution of the two wheels.
I know, lol, everyone overlooked that I said it was a 1" difference in diameter but the actual area traveled is a HUGE difference! When are those 12 second times coming dan?
ill be getting my 13.3 when i get my damned shift cables fixed
hey thats about what im running!
i ran 14.0 @ 109 lol lost .7 due to shift cables not allowing me to engage 2nd fast
u must have killer traction and 60' then
except your numbers are wrong. its more like 812.5 for the 215/45/18 and 844 for the 215/45/17 taken directly from pirelli's website
Not all tires are the same, even if the sizes are, but I'll agree that it's a far cry from Pirelli's 844, so who knows? Even at the numbers you say, that's not enough difference to make up for the difference in shift points.
not a great 60 foot, 2.16. holy cow you must have been spinning like hell though to trap 109 in a 14.0 run
no...I just make lots of power
my shifter cables/clutch prevent me from shifting 1-2 fast...my datalogs show im losing .7 seconds on teh 1-2 alone
also that is with a 2.3 60'
if I had a 2.1 id be in the 12s...what tires u running?
I went by Tirerack.com, and used the OEM tire (which for the Redline is a Dunlop, not a Pirelli). Clicky.
i still think it would effect ratio somewhat, but not by as large of a margin that this particular thread starter is talking about
the 64 vs 72 may be 65 vs 70 or 64 vs 71, I dont know exact, especially his car, but I know mine seems to be @ or above 70, and he says is his below 65.
I am running the 2.5 HFC, and to be honest, I would have rather bought a header then the HFC. There may have been some gains from it, but I dont believe it to be as much as you would get from a header. It may complement a header though, as I think it did with my bro's car. It does make an odd noise, so you may want to think twice before you purchase. Mine is very non noticable, but my brothers is f00king anoying.
As far as rim weight, I believe the Cobalt w/ tires weighs in at 24 lbs, and the Redline at 21 lbs per rim.
Rims alone are 21 for cobalt and 18 for Redline.
Hes not really faster then me though, he only seem to be faster when I am way out of my power band. a 20 MPH roll in 2nd means I am sitting at like 2000 RPM's. He pulls from this kinda launch. From a 40 where we both are peak power, we are neck and neck except when he shifts and then I start pulling.
The dood w/ the 2.6 inch pulley. Obviously you have bigger mods then us. You would have had to get tuned w/ the 2.6, where as me and my bro are on the stock GM stage 2 tune. You better be faster then us or I would feel sorry for you. I ran 13.7 on stock BALD perelli's (still on my car) w/ a 2.25 60 foot in blistering heat. IM sure I could hit very low 13's w/ the tires in my closet and normal temps out.
Darksun what is the status on ur car?
