getting to 12's
Old May 24, 2007 | 11:38 PM
peck05's Avatar
getting to 12's
hey whats up everyone, i have really big plans for my car and i have alot of items that i am just waiting to buy,if anyone has seen my recent post i sold alot of parts that i bought b/c i got into alot of trouble a while back. but i am amble to mod again so im going all out. i plan on getting to 12 seconds
i currenty have the stage 2 with a injen intake and a 2.8 pulley on,
my parts that i am ordering hopefully within the next month are
1. 2.7 pulley
2. 60# injectors
3.2nd stage spark plugs
4. engine damper
5. stage 2+ clucth
6. ca front mount heat exchanger
7. meth kit
8. header & downpipe with high flow cat
9. hp tuners(already on teh way)
10. sway bars
11. wideband and interceptor gauge.
ive been saving my money for the past 3 months or so, i plan on just ordering everything at ounce and puttin it all on tehn tuned right away. i think i got alot coverd, but i still need some help, if i havemissed anything at all, please let me know. thanks alot
Old May 24, 2007 | 11:41 PM
tREBs's Avatar
axles, pistons, cams, to build a high hp motor you need the supporting mods first...
Old May 24, 2007 | 11:46 PM
alaskacobalt's Avatar
The sticker mod is a good one too... add about 50 stickers on there and you should easily be able to pull some incredible power thanks to the VTEC gods... this might only apply to ricers though... but I'm sure if you throw a primered body kit on your car that will help and an exhaust tip that you can hear across town...
Old May 24, 2007 | 11:58 PM
ItalianJoe1's Avatar
I'm thinking some nitrous on a setup like mine should be good for close to 12's. Will probably need slicks and therefore axles to hit it though. I guess I'll find out eventually!
Old May 24, 2007 | 11:59 PM
bojan's Avatar
add
slicks
axles
Old May 25, 2007 | 12:23 AM
Mikey851's Avatar
Originally Posted by bojan
add
slicks
axles
Definately; or at least drag radials.
Old May 25, 2007 | 12:25 AM
Ljavy17's Avatar
itll be hard to hit 12s on a 2.7 even with meth, Youll need the tq of a 2.5"
Old May 25, 2007 | 12:26 AM
peck05's Avatar
do you get any belt slip with a 2.5, i see you are running it now, how is yours holding up?
Old May 25, 2007 | 12:28 AM
Mikey851's Avatar
Similar to your thread, he should probably either keep the 2.7" or go to a 2.9" or so and use a 50 shot. With a pulley in that range, a good tune, and a 50 shot he could pull off a high 12 with axles and drag radials.
Old May 25, 2007 | 12:29 AM
Ljavy17's Avatar
holding up really well on a stage 2 GM belt.
Rangerondubz's Avatar
Werd Up
Old May 25, 2007 | 12:31 AM
Ljavy17's Avatar
Originally Posted by Rangerondubz
Werd Up
WHY DO YOU ALWAYS SAY THAT!!!! lol.
Old May 25, 2007 | 12:38 AM
Werd Up
Old May 25, 2007 | 12:42 AM
1gmfanatik's Avatar
Actually, I do not believe it is all that tough to hit high 12's without droppin pullies all the way down to a 2.5"...I'm runnin a 2.79" pulley with 42lb injectors, Vibrant 3" cat-back (big future plans) Injen CAI, ZZP front tranny mount, Eibach Sportlines, Cobra HE, Hurst Shifter and a bangin Tune Time tune by Matt, and I truly believe that I am in the low 13's right now. High 12's are not that far out of reach if you know how to take advantage of the cars potential.
Old May 25, 2007 | 12:48 AM
peck05's Avatar
^^ hell yeah, deffinitly have to keep me posted if you run and your times.but i think iwill be pretty close with that set up i have picked, think its pretty solid
hatrickstu's Avatar
oh my gosh people, one person names stickier tires. ONE. im through trying to get it into the thick skulls on this site that these cars need traction before adding power.
Old May 25, 2007 | 12:52 AM
1gmfanatik's Avatar
LIMIT BOOST IN FIRST GEAR!!! I'm telling ya, once you do that, the car is a whole nother beast. I have the LSD, and we limited boost in 1st, and she chirps em a bit then rolls out. My stock Pirellis have almost 17K miles on em, but then I haven't been out smokin em up everytime I drive. lol
I do agree though Hatrick..I truly believe that with ONLY suspension and wheel hop mods, that our cars are more then capable of high 13's out the box with NO power adders.
Last edited by 1gmfanatik; May 25, 2007 at 12:52 AM. Reason: Automerged Doublepost
Old May 25, 2007 | 12:56 AM
Mikey851's Avatar
Actually three people said to use stickier tires and the first person mentioned that you would need axles with them.
Old May 25, 2007 | 12:57 AM
peck05's Avatar
one more question. do you think that set up would run ok with a dual pass plate rather then the full heat exchanger?
Old May 25, 2007 | 01:00 AM
hatrickstu's Avatar
your right mikey my bad. i just get so mad always reading about how people want power, power, and more power. when i guarentee you a stock ss/sc with dr's and a torque dampner will smoke the majority of people runnign only stage 2 (or similar power adder)
Old May 25, 2007 | 01:01 AM
1gmfanatik's Avatar
Run both..There is nothing wrong with doing what you can to lower them temps. Mine does run a bit cooler when sitting in traffic now, compared to before the HE, but I still plan on doing the Dual Pass still also. Lower temps = More efficient Power..Damn, I sound like NJHK..lol
Old May 25, 2007 | 01:02 AM
SlayeR36987's Avatar
Im not sure bout that but if ur not lookin on spendin all that much u can drop ur temp. bout 40 deg. if u went and got a Cobra H/E and you can get the brackets from http://bwoodyperformance.com/.
Old May 25, 2007 | 01:03 AM
peck05's Avatar
ok thanks, i really appreciate everyones input on this, keep them comin, really helping me out
Old May 25, 2007 | 01:05 AM
1gmfanatik's Avatar
Motor mounts, stiffer springs and shocks and struts or Coilovers, and axles will get you in the high 13's without the DR's if you know how to launch. The DR's are nice, but if you don't know how to launch with em, then you may slow yourself down. At least the first run or two. Our factory tires are not bad tires, when there is tread left on em. lol.
peck05's Avatar
i herd the cobra heat exchanger was pretty hard to install. i know there is a how to on here i was just reading about it!
