GMPP Clutch' In Stock
Old Oct 26, 2016 | 11:03 AM
CrateEngineDepot's Avatar
GMPP Clutch Kits Back in stock.
#19212712 GMPP Clutch Kit
Link
We also are running a special on the LSJ flywheel PN 12584343
Normal price $ 432.89, now on sale for $329.95 while supplies last.
Link
#12584343
Old Oct 26, 2016 | 01:01 PM
63 Nova SS's Avatar
Would highly recommend except on high hp builds. Tom is a good guy to deal with, and they ship fast.
Old Oct 26, 2016 | 07:06 PM
loved this clutch in my TVS balt. great product from great company
Old Nov 23, 2016 | 09:04 AM
stagewtf's Avatar
Are these good?
Old Nov 23, 2016 | 10:09 AM
63 Nova SS's Avatar
Originally Posted by stagewtf
Are these good?
Best clutch for the money hands down under about 400ftlbs of torque. The stock flywheel is expensive though, and most are trying another route there. Thanks GM.
Old Nov 23, 2016 | 10:22 AM
stagewtf's Avatar
What flywheel should I put with it?
Old Nov 23, 2016 | 10:32 AM
An OEM one or OEM weight one (Luk makes one)
Old Nov 23, 2016 | 10:39 AM
rocco11189's Avatar
Great clutch! Bought one off Tom about 2 years ago. Cant believe how much the flywheel has sky rocketed since then
Old Nov 23, 2016 | 04:14 PM
stagewtf's Avatar
OEM? Can't be a Fidanza?
Old Nov 23, 2016 | 06:59 PM
We have the OEM flywheels on special right now.
Buy em while I have em.
LINK
Old Nov 23, 2016 | 08:11 PM
Sharkey's Avatar
you can use a fidanza if you choose. im running a fidanza and gmpp clutch, been in my car for more than 5 years now, never had an issue. id rather have a heavier flywheel in a daily driver though, easier to drive.
i used a fidanza in my l61 ecotec swapped 944. coupled with a spec 3+ clutch it was a bit of a bear to drive nicely, and i had to have the idle higher than i wanted to get it stable (aftermarket ecm, 850cc injectors). long story short i had to replace the flywheel (started failed, damaged ring gear) so i put an exedy chromoly flywheel in. far smoother idle and way easier to drive. if i ever pull the trans back out of my cobalt, its getting a steel flywheel put back into it.
Old Nov 25, 2016 | 03:14 PM
stagewtf's Avatar
I'm definitely taking some notes on this. I'm running a KY stage 4 with a Fidanza. A pain to daily but I do it.
