Going Turbo Few Questions
Old Aug 3, 2010 | 02:57 PM
Bl4des's Avatar
ok so i am going with a simple turbo set up at first i am getting zzp turbo only kit. they no longer make the rotor delete plate so i am going with the supercharger delete plate. because i am going to run it with the stock intercooling system for a little bit
so with the delete plate the throttle body with be mounted to intake manifold and i need to know how to get the one non flexible line that goes to the throttle body to were it is going to be now
and what is the easiest way to change how the belt is set up weld the alternator clutch or use a 2.2 alternator
i have welding equipment that i can use
Old Aug 3, 2010 | 03:04 PM
cobaltguy889's Avatar
get a 2.2L tensioner and alternator. You will have to order the pigtail through tom at CED for the new alternator plug.
Basically all you do is remove the lsj alternator bracket and tensioner setup, and install new tensioner (2.2L) with 2.2l belt, and install the alternator without the lsj bracket.
What flexible line are you talking about?
Old Aug 3, 2010 | 03:06 PM
Bl4des's Avatar
the line that is not flexible i will go take a pics
Old Aug 3, 2010 | 03:08 PM
BLAZIN07SS's Avatar
I'm too JDM for you
the evap line. you can heat it up with a blow dryer and bend it
Old Aug 3, 2010 | 03:10 PM
Bl4des's Avatar
is it just a vacuum line and i can just replace it with a hose
i will be using this
Old Aug 3, 2010 | 03:13 PM
05Slowline's Avatar
non flexible line? you mean the black evap? just gotta cut it in half and put rubber vacuum hosing/clmaps on mating sides.
easiest way is prob weld lsj alternator and get 2.2 tensioner and belt
or do what blazin said if that works too lol
Old Aug 3, 2010 | 08:21 PM
Bl4des's Avatar
i dont have my stuff yet but what do i do with the other line that is going into the supercharger i am not sure if there is a spot for it on the charging pipe
were can i get the pig tail for the 2.2 alternator i don't see it on ced
Old Aug 3, 2010 | 08:26 PM
05Slowline's Avatar
dont, just weld your alternator idk why you would buy stuff when you said yourself that you can weld for free lol
Old Aug 3, 2010 | 08:30 PM
Bl4des's Avatar
i didnt feel like welding it i already bought a 2.2 alternator
is the belt tensioner from a 2.2 cavy the same as the one on the cobalt
Old Aug 3, 2010 | 08:33 PM
05Slowline's Avatar
lol you realize it takes like 2 minutes maybe to do the weld to it? whatever though just costing yourself money.
http://cgi.ebay.com/ebaymotors/GM-2-...s#ht_500wt_956
cheaper than anyone here will sell one for, i actually don't know why i posted it i should pick that up for 20 bucks lmao
Old Aug 3, 2010 | 08:51 PM
Bl4des's Avatar
thanks for posting that just bought it i looked on ebay before and didnt see that
ok so last question what is the vacuum line for the is going into the supercharger right after the throttle body i dont think the charging pipe i am getting has a spot for that
and where on ced is the pigtail for the 2.2 alternator
Old Aug 3, 2010 | 08:53 PM
BLAZIN07SS's Avatar
I'm too JDM for you
the vacuum line going into the blower is for your boost bypass valve. you don't use it anymore so it doesn't have to connect anywhere
Old Aug 3, 2010 | 08:55 PM
Bl4des's Avatar
no the big one right after the throttle body
Old Aug 3, 2010 | 08:58 PM
BLAZIN07SS's Avatar
I'm too JDM for you
oh thats your brake booster hose. don't know where you would hook that up on that adapter
Old Aug 3, 2010 | 09:01 PM
ikeryder13's Avatar
whats that for?
Old Aug 3, 2010 | 09:03 PM
Bl4des's Avatar
ok i will figure out a way to hook it up
Old Aug 3, 2010 | 09:19 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by ikeryder13
whats that for?
brake booster hose? it provides vacuum to the brake booster and "boost's" your braking.
Old Aug 3, 2010 | 09:24 PM
Bl4des's Avatar
is there a 1 way valve in the elbow or something so it is not pushing air into the brake boost wail in boost
Old Aug 3, 2010 | 09:27 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i believe so but i have heard of people blowing up their brake boosters on big turbo set-ups
Old Aug 3, 2010 | 10:22 PM
Bl4des's Avatar
so i am going to need to tap the intake manifold or the adapter plate for it to work unless the is another vacuum line i can hook it up to
does anyone know what kind of fitting i will need for the brake booster line
ok so i just went and took off the elbow and there is no 1 way valve so i guess that means it doesn't matter if are brake boost sees boost
Old Aug 4, 2010 | 04:36 PM
Bl4des's Avatar
so i have everything on order that i need except for the pig tail for the 2.2 alternator can i order one somewhere or do i need to go to a junk yard
Old Aug 4, 2010 | 04:46 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you already ordered your zzp stuff?
Old Aug 4, 2010 | 04:49 PM
Bl4des's Avatar
yeah i did it should be shipping by the end of the week
is this the plug
http://www.oehq.com/acdelco-parts_AC...0Connector.htm
Old Aug 4, 2010 | 05:01 PM
selfinfliction's Avatar
ebay for less than $30 shipped
oh you mean the wire... uhh one sec
yeah that one you posted works
Old Aug 4, 2010 | 05:03 PM
Bl4des's Avatar
is this it
