Going Turbo - Need Some Advice
OK, so my plan is going full turbo. I'm looking at the T3/T4 or the GT32 type turbos. I want to make sure they will fit behind the engine good or not. I was going to run the turbo manifold on ebay that Adam mentioned in a post on here.
So I'm running stock internals right now, looking to push 320-330whp for now. I'll be looking for around 450whp after internals. The car isn't driven daily either. It's mostly used for cruizin around and going to the quarter mile track. I do want the car to be streetable though, low lag time.
So what trim and stuff should I be looking at?
Turbo is the way to go, you should easily make 350WHP on stock internals as long as you have a proper fuel setup and tune.
re
My suggestion:
Garrett Gt2871 Ball bearing turbo (good to 400hp) 52 trim (compressor)
Tubular Style Turbo header
Blow off valve
Electronic Boost controller
Charge pipe to Thottle Body
All Fittings for oil supply and return to turbo
Air filter
Custom Throttle Body elbow to adapt to your lower intake
Performance Clutch
Use your Stock water to air intercooler (you already have the dual pass endplate)
Options
Turbo Timer
You already have:
60lb Injectors
HP Tuners
Exhaust (downpipe and Magnaflow)
Running 20-21psi you should be in the 330-350whp range with minimal Lag, on stock internals.
Or go with a GT2876, the GT3071 will flow more but you will lose short lag, the larger GT3071 turbo will spool up above 3500rpm!
Thats why I suggest the smaller GT2871 or GT2876 Turbo, that will put you in the mid to low 12's
Blow off valve
Air filter
Performance Clutch
Options
Turbo Timer
You already have:
60lb Injectors
HP Tuners
Last edited by QuikSilverSS; 05-15-2007 at 01:08 PM. Reason: Automerged Doublepost
JBP Custom Cylinder Sleeves
Stock girdle
JBP 4340 Cross-Beam Connecting Rods
JE Forged/JBP Forged (8/8.5:1)
H11 Custom Wrist Pins
Hastings Moly rings
Crower Custom Billet Steel Crank
Annealed Copper with O-rings head gasket
H22 Studs/Arp studs
Custom Cam (.465 /.467 221/221 degrees)
Dry Sump
Head work.. large valves + 3 angle port job (272 cfm of air at 0.450 lift and 175-207 cfm exhaust) use #'s as a guide to how work is going
Stock girdle
Hastings Moly rings
H22 Studs/Arp studs
Dry Sump
are superchagers that bad? i like turbos and superchagers both, but it seems so many people just go turbo, i know the turbo holds more power in this situation but is it just our stock superchager, is there another one that can handle more power for our car?
superchargers become far less efficient due to being belt driven with > parasitic loss + heat.. the M62 we are using is a descent blower for a stock vehicle but when wanting more.. it just isnt "big" enough for the numbers most of us are seeking... either swap the blower or swap for a turbo setup is only way to improve... need greater volumtric efficiency and a tc/sc that can get your the CFM we seek without being "redlined"
The m62 puts out more cfm than an evo 9 turbo and they get 425-450 AWHP also if you do head work and cams it will bring it into to its proper effiency range and it will no longer be a heat pump.
Flow at Max. Speed @ 1.8 Bar: 810 cubic meters / hour
If I have some time, I'll see if I can get that to a comparison of something I'm more familiar with.
If you notice, even the turbo swaps don't net much more than 320whp on average. (there are some exceptions I know, but overall) This is probably because of the stock valvetrain's limited flow capability. After partaking in djt81185's turbo swap it really isn't worth the money imo until you start modifying the top end. If you plan on keeping the top end stock, my opinion is to just go with a bottle to hit the 320whp mark, just because of the cost and ease of fabrication and installation.
Not saying you are right or wrong, cause I honestly don't know what the M62 is fully capable of, but if it helps, here is what Harrop lists as the max flow capability:
+11xbillion
everybody wants power.. but everybody wants to be cheap and think more boost will do it.. then we hear alot of crying with "i blew my **** up"... people really need to learn more about motors and stop being sheep into the demise of blown up motor heaven
I wasnt saying that making 500whp was cheap either. You will have to CNC port your head you will need a full 3" exaust, valves, springs, retainers, and some fat cams but it is possible. ps pistons and rods
Correct me if I'm wrong, but i'm thinking that a GT35 is WAY too big of a turbo for the ecotec. Using conservative figures I can see a GT3071, but not anything bigger then that. GT28 will probably be the best bet for the track, bigger is only better if you want more horsepower then you'll use in the 1/4
I'm thinking also going turbo. I was looking at the sts turbo site. This is a remount turbo installation freeing space under the hood. Also, check out on the web page there is a 2.2 L ecotec with the system installed.
ststurbo.com
06 Cobalt/ stock
ststurbo.com
06 Cobalt/ stock
I woul think that in either case you need to do engine work to get to the power goals outlined here. But if you take the ability to run turbo or SC I think the turbo is going to net more power in the end but with a sacrifice in low end due to lag. In the SAAB world using the previous gen motor (ECOPOWER) we have seen 350+ WHP on a GT2871R with proper tuning.
What options are there on porting or upgrading the stock blower on the SS/SC? Also what about using water/methanol injection to control intake temps and such?
Remount turbo setup
Ok, guys. check ststurbo.com This is a remount turbo installation freeing space under the hood.
http://ststurbo.com
There is a 2.2L ecotec with this system installed. Gains depends on the installation kit. Gains in average are more than 120HP.
One more thing. It seems it is best to use a return-fuel system. A good friend of mine has a Scion tc. He added a turbo with an aeromotive fuel pump (creating a fuel-return system) .
Lots of gains - 280 HP @ 13psi running stock internals.
Notice,
Blown #4 once because of overboost (15+ psi).
By the way, I'm Jose, an electronics and math professor on Puerto Rico.
It has been very hot these days. BTW, good info on this site.
http://ststurbo.com
Notice,
I'm not only using it on the track, but on the street too. I want it to be quicker than it is. I'm not touching the engine yet. I want to make sure I have a turbo I can run at lower boost and crank it up in the future once I get the internals done. The GT 30 might be the best for that?
Ok i just double checked some math and the M62 puts out the same cfm as the EVO9 turbo about 600CFM so with parisitic loss you should still be able to get around 450whp, also in addition to that you can get the supercharger ported.
