Got Meth?
Old Mar 28, 2008 | 11:27 AM
hawlyns711's Avatar
Originally Posted by Area47
280+ whp here on a 3gph nozzle.
i dont believe you
Old Mar 28, 2008 | 11:30 AM
Area47's Avatar
Rent me! per hour
lick my *****
Old Mar 28, 2008 | 12:10 PM
2K5SS/SC?'s Avatar
Originally Posted by Cyclone
SO is it always on and will spray when it hits your setting or do you have to turn it on then it will spray like nos??
??? any one??
As I posted above, "Remember, you control when it sprays and when it doesn't. It's not a constant spray when the car is running, it's only when you hit a certain psi for the boost switch or a certain MAF hertz if you have a progressive controller."
This means the kit will only start spraying when you hit the preset boost you manually set. I have mine set around 8-10psi. Anything below that now spray, as soon as I hit 8-10psi BAM spray all the way until I go below that 8-10psi again.
I believe it.
Old Mar 28, 2008 | 01:30 PM
07cobaltss's Avatar
did ya have some extra wireing after the install....lol
Old Mar 28, 2008 | 03:49 PM
Mattman6's Avatar
sure did haha, but I got a lot of cut down a lot shorter. Now I need a freakin checkvalve so the meth isnt dripping onto my MAF
Old Mar 28, 2008 | 03:53 PM
2K5SS/SC?'s Avatar
Your kit didn't come with a checkvalve? That is some shady **** right there!
Originally Posted by QuikSilverSS
I am just running the stage 2 tune right now, until I get my 60lb injectors, custom tune on and my 2.8" pulley next week, however the M5 is making the stage 2 tune even more super rich...I am in the high 9's low 10's a/f wise at WOT...defentaly not great, however with the tune I will be able to lean the a/f out and bump the timing...I think the max timing on the stage 2 tune is like 15 degrees???
I am just going by what I noticed with my aeroforce...was still getting some knock with the M3 nozzle on the stage 2 tune, switched to the M5....and then zero knock (runs pig rich though)
We also can only get 91 Octane fuel here in Canada so I am not sure if that has something to do with it.
I just read the post by AIS and decided to try it out, and it worked for me no knock with the larger nozzle
Oh, 91 octane is **** gas. That sucks, and then yes a M5 jet would assist you better. I thought some stations up there had 94 octane? Hmmm....
Old Mar 28, 2008 | 04:05 PM
hungryhip-ccp's Avatar
that must be the worst gas in the world... i never saw knock on the stage 2 tune, **** they dont even give you enough timing to do a knock knock joke
Old Mar 28, 2008 | 04:34 PM
Mattman6's Avatar
Its not that it didnt come with one, I custom built a kit, i know i know i should of got a checkvalve, but I talked to a few people and they havent been running one Pre-TB and theirs works good. But ill get one and see what i get then.
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
