Got my Devil's Own Kit in today!
Old Apr 16, 2007 | 01:02 AM
memphisr24's Avatar
Is this better than snow performance??
Old Apr 16, 2007 | 07:49 AM
fastSS06's Avatar
Originally Posted by BoomInIt
Could you mount the nozzle on the intake in the wheel well? then it won't be seen at all...
Or is that to far away from the intake manifold?
Ur car won't like it when the nozzle sprays on the MAF
Old Apr 16, 2007 | 08:12 AM
2K5SS/SC?'s Avatar
That's for sure. What size nozzle are you running? I just put the 3M one in which is 3gal/hr after some reading. I might order the 5M one since the three provided were 3M/7M/12M. Hopefully I can get some timing added this week too. As for emptying the bottle, I used the hell out of it Saturday night with the 7M nozzle, and it barely went down at all. Kept the blower nice and cool and the intake was like ICE!
Old Apr 16, 2007 | 08:25 AM
yellowcobaltss05's Avatar
damn man looks good!
Old Apr 16, 2007 | 08:33 AM
KindredX's Avatar
I don't want to come off as a noob, but when it comes to the Alcohol Injection Kit I don't have a clue about them, would it benefit me at all with my current mods. I have never messed with one of these kits, but it sounds like a great mod to go with.
Old Apr 16, 2007 | 10:32 AM
fastSS06's Avatar
5M nozzle
Old Apr 16, 2007 | 05:35 PM
FSRbikr98's Avatar
Originally Posted by Ljavy17
isnt that kind of low for an srt4 with meth.
I have gained 44 horsepower and 65ft/lbs or torque with a boost controller, downpipe, and alcohol. I think thats pretty astonishing. I have no port work, stock intercooler, stock throttle body, stock o2 housing and catback, the only exhaust piece i have is a 3inch downpipe. Stock injectors, and its a mild tune with my air fuels at about 11.6 across the board. I'd say thats pretty impressive
On o6black's cobalt, the meth was the determing factor if he made 275hp or 296 like he did.
The alcohol/water will do a number of things. First and foremost, alcohol is like pure octane, so depending on the mixture u run, you could turn that 93 octane you are running into 100octane at a fraction of the cost.
Second, the water will cool the intake charge, lowering your intake air temps, and on a supercharger setup that creates a substantial amount of heat as you increase boost, it'll work wonders. I've seen 06blackg85's cobalt in person, and the meth injection made his dyno run, and probably has saved his motor countless times. At the track he was recording 180degree iat's (no meth), compared to the 120's he was seeing with the meth turned on
Old Apr 16, 2007 | 06:19 PM
burntorange's Avatar
Yeah, I am really considering a meth setup now. I rode with a friend with an EVO 9 running about 30psi on a COMPLETELY stock setup only mod was meth and man it was VERY impressive. And it looks cool having two tanks mounted on the back of the rear seats and a cool looking pump with braided steal lines.
Old Apr 16, 2007 | 07:12 PM
FSRbikr98's Avatar
Originally Posted by denny
Does this kit come with a solenoid to avoid the engine on vaccum from sucking in the meth?
I am unfamiliar with the devils own kit, but most meth kits will come with a mechanical check valve. Usually these valves are rated around 40psi, so as not to leak under vacuum. Honestly the best setup to avoid lag in the system is to use an electronic valve that opens as the meth turns on.
Old Apr 16, 2007 | 07:20 PM
patathSS's Avatar
This isn't necessary when spraying before the throttle body. I have the same kit and it comes with a check valve.
What boost level do you have yours set to kick in 2k5? Did you hook up a light for it? I had a LED hooked up but I keep burning it out. I think it is because I have it hooked inline with the power so it keeps spiking the power to the LED. Just wondering what you did.
Old Apr 16, 2007 | 07:37 PM
  #36
djt81185's Avatar
The DO kit comes with a mechanical check valve
Old Apr 16, 2007 | 11:46 PM
  #37
2K5SS/SC?'s Avatar
The kit has a mechanical check valve. See the intake nozzle pic in the thread and you'll see it attached to the 90* bend. It's silver coated brass.
I have mine set right now to come on around 10psi. It seems to work pretty good there. I still need to add timing, but I think I'm going to order the 5M jet first and install it.
Old Apr 19, 2007 | 02:39 PM
  #38
memphisr24's Avatar
Here is the total engine compartment view!
Here is the boost sensor.
I have a question. Does this boost sensor have to go in between the boost bypass actuator and the valve? Or can you install it before the valve? Because i'm on the boost bypass mod, and it's the only way I can hit full boost since something is wrong with my car. Therefore, that rubber tube is not connected to my actuator.....
Also, when ordering it, do we order the 2 bar or 3 bar controller? I'm a bit confused there.
Old Apr 19, 2007 | 02:49 PM
  #39
BlackSS/SC's Avatar
i was told by them that the 2 bar kit reads maf frequency.
Old Apr 19, 2007 | 02:51 PM
  #40
memphisr24's Avatar
Alright, 2 bar it is....but what about my dilemma
Old Apr 19, 2007 | 02:54 PM
  #41
BlackSS/SC's Avatar
Not sure about the other thing, sorry man.
Old Apr 19, 2007 | 02:59 PM
  #42
memphisr24's Avatar
Here, it might be easier to explain it this way.....
THat line right there is not connected to my boost bypass actuator.....any ideas on how I could still run the meth kit?
I think they sell something that runs off volts...but i'd rather not do it that way
Wait, I think I may have an idea....Could I connect the line to the Actuator itself, and just route it into the boost sensor?
Last edited by memphisr24; Apr 19, 2007 at 02:59 PM. Reason: Automerged Doublepost
Old Apr 19, 2007 | 03:06 PM
  #43
memphisr24's Avatar
Originally Posted by PAPERSUN
[ Just to let everyone know that in june gm will stop making the ss supercharger cobalt. They were suppose to follow that with the turbo but plans for that have fallen back till next may of 2008, either as a late 08 or 09. So as of now, no new tuner cobalt till april or may of next year..i saw the memo at work last night at the gm lordstown plant..
QUOTE=2K5SS/SC?;972210]Well, the UPS guy was kind enough to drop off my Devil's Own Methanol/Water injection kit today. I must say the kit is a nice setup. I've installed one on an Audi TT before and it worked great, so I hope it'll do the same for me. I'll be installing it on Saturday since I have to go to Chicago for a couple days, so stay tuned! Pictures and more power to come!
[/QUOTE]
What does this have to do with the Devil's Own Meth Injection kit??? Please stop posting on this forum
Old Apr 19, 2007 | 03:25 PM
  #44
Red2.4SS/SC's Avatar
NO MORE SUPERCHARGED COBALT YAY , also 2k5ss/sc how much did you pay to get the meth kit shipped to your door and running
this is gonna be my next mod
Last edited by Red2.4SS/SC; Apr 19, 2007 at 03:25 PM. Reason: Automerged Doublepost
Old Apr 19, 2007 | 06:18 PM
  #45
FSRbikr98's Avatar
good choice you'll love it
Old May 4, 2007 | 09:46 PM
  #46
Ljavy17's Avatar
he blew his tranny.
Old May 18, 2007 | 12:20 PM
  #47
can u use this kit with the cobalt addiction throttle body spacer?
Old May 18, 2007 | 12:24 PM
  #48
BlackSS/SC's Avatar
Yes you can. Also what you see on the controller for turn on points on the progressive kit, our car has a 2.5bar MAP sensor and their kit is for 2 or 3 bar. I'm working with them on this now.
Old May 18, 2007 | 12:33 PM
  #49
ok bc im looking into buying this one and i want to make sure that it will hook up the same as the snow performance kit bc Ljavy17 is installing it for me and he has the snow kit.
Old May 18, 2007 | 12:38 PM
  #50
BlackSS/SC's Avatar
The Snow kit hooks up the the MAF sensor, the Devils Own kit hooks up to the MAP sensor if you get the progressive kit.
