Gutted cat??
i guess the sound gets in there and bounced around that chamber and it amplifies the trashy sound.
if you do anything, just cut it out and have a pipe welded in its place
ok regardless if i do it or not i will get a CEL if i gut it or if i get a test pipe! So the only way to get rid of the CEL is with a tune. No antifolers or anythin will work?
no i have no cat yes either way it will throw a cel but i get a spacer from ARK that moves the O2 sensor out of the pipe a litle to make it think it's going through a cat i have one and several other people on here have one no problems for me
Ok when i looked under the car i saw that the o2 sensor was fairly close to the chassis, you was still able to get a fouler in there with the o2 senosor also?
