H E L P !! Water on Filter??
Old Dec 13, 2011 | 11:29 PM
The Azian's Avatar
I just drove my car through the rain all day and I feel like I got water on my filter and possibly sucked into the motor? Also I had major bog and white smoke from tailpipe. Any help here??
Old Dec 13, 2011 | 11:36 PM
Blowncavy's Avatar
Hope it's not an head gasket
Check your oil and your antifreeze level, spark plugs . How much water you suck up?
Old Dec 13, 2011 | 11:39 PM
Black SS/SC 06's Avatar
Did you check the filter to see if it was wet? They make a hydro shield to prevent water from getting in your filter. Also what type of filter do you have. Dry or oil based?
Old Dec 14, 2011 | 12:14 AM
The Azian's Avatar
Oil looked fine, and I'm not sure I sucked up any water I was just wondering if anyone else had the problem of bogging from water or anything
Old Dec 14, 2011 | 12:16 AM
The Azian's Avatar
The filter did appear wet.. Do u no the website for hydro shield? Aware if it helps at all? And I have a dry filter
Old Dec 14, 2011 | 12:17 AM
insylem's Avatar
Said something dumb and wanted to delete it but it wont let me delete it and if I leave a blank it says its too short.
Chevycobaltss3's Avatar
Also after you check Ure engine for health, clean Ure maf. And sensors.. just in case
Old Dec 14, 2011 | 12:19 AM
insylem's Avatar
Right here
K&N Air Filter Wraps
Old Dec 14, 2011 | 12:21 AM
The Azian's Avatar
Thanks guys on the filter wraps! I think that might help out alot!
Old Dec 14, 2011 | 12:22 AM
The Azian's Avatar
Yea I was thinkin possibly the sensors got wet somehow?
Old Dec 14, 2011 | 12:23 AM
cmatthewb101's Avatar
Did you get a check engine light?
Old Dec 14, 2011 | 12:25 AM
The Azian's Avatar
Sure did
Old Dec 14, 2011 | 01:06 AM
sport08's Avatar
Did u get the code read if not u should
Old Dec 14, 2011 | 01:08 AM
insylem's Avatar
I think a compression test is a good indication of the overall general health of an engine.
Yea, reading the code will tell you exactly whats wrong....
Old Dec 14, 2011 | 01:16 AM
insylem's Avatar
Not always:
When I baught my car it kept saying "P0172 System Too Rich Bank 1"
Instead if it was telling me what was wrong it should have said "I'm running 42# injectors on a 2.85" pulley with a stock tune"
Old Dec 14, 2011 | 01:19 AM
cole3883's Avatar
you definitely shouldnt have bought the car if the previous owner ran 42's and a 2.8 on the stock tune lol..
Old Dec 14, 2011 | 01:42 AM
insylem's Avatar
The previous owner had an intense tune in it based on the intense stickers on the PCM. I called up intense and the guy said that what probably happened is that the dealership reflashed the tune back to stock when they got the car. I probably shouldn't have baugth the car, but I didnt know it had 42s and I didnt realise that the 2.85" wasn't stock, also didnt see the intense sticker on the PCM. Well now I have a ZZP sticker on it and running 60s So I got tha nonsense straightened out.
Old Dec 14, 2011 | 02:08 AM
heathkidder's Avatar
had this happen to me in august or so. your maf sensor is wet you need to take it out and clean it and get you a hydro shield to protect it. my car would blow white smoke and when i went up a hill it would die and then start right back up and go thats why i now have a sri lol but you best do it before you get hydro lock on your engine once you clean it i let the car idle for 15 min
Old Dec 14, 2011 | 02:32 AM
You may want to consider switching to an oil based filter. They seem to repel water better.
I believe a few of the vendors on here sell the hydro shield. I used it when I lived in Wyoming and it seemed to help.
If you still have the CEL tomorrow run up to an auto parts store and have them check the code. You might have just got water somewhere and it will dry and the CEL will go away. You never know.
Old Dec 14, 2011 | 02:34 AM
Yea the dealers usually reflash back to stock so they can sell their warranty crap. Alot of times its actually worse for the car
Old Dec 14, 2011 | 08:52 AM
Vander Nars's Avatar
A dealer shouldnt ever reflash a cars tune unless they know the parts are stock they just stupid
Old Dec 14, 2011 | 09:29 AM
HMM i didnt think about switching to the oil based k&n yet on my injen cai...
the shield I got doesn't seem to do ****, i went to clean it one time by running water on it and it went right through like its was a window screen
Old Dec 14, 2011 | 09:50 AM
LopsidedJester's Avatar
I never had a problem with oiled filters, i would recommend you get one. I've only had problems with GM's tunes with aftermarket CAI.
Old Dec 14, 2011 | 12:23 PM
Bika's Avatar
Fail Less.
I highly doubt the water did any internal damage to the engine if it's still running. If it did anything it would hydro-lock a cylinder and it would have seized or completely stalled out.
Read the code and go from there.
The stock airbox works great as a hydro shield Drove (slowly) through over a foot of water with it and didnt suck up anything. Just don't let it sit and submerge.
