HAHN TURBO CONVERSION for ss/sc
i dont know much about this company but their stage 1 and 2 kits look interesting, any opinions on this compared to the supercharger stage kits?
http://www.turbosystem.com/ProjectVe...ent%20Page.htm
the part listing is here
I mean if you have the knowledge you could piece together a kit and save some money, But its not easy and you will still need most of the stuff in that kit whether you buy it from them or somebody else.
Thing is that kit will make 400whp, Not right out of the box but with a good tune a few tweaks here and there.
There really isnt a cheaper way to make that kinda power
Stock rims will handle a good size tire, The problem is what will fit in the wheel well. Im running a 225/40, I have seen people run 235's with no issues, And if i remember correctly i think i seen sombody was running 245's with very minimal rubbing when turned all the way to the lock
i think ill get 235 summers than and keep my 215 stocks in the back, my front tires were cooked, but the rears are fine. i havent decided which brand, but i need something that will work well with 250+whp
I would go with these, G-force Sport
Or the next step up, KDW's
Level V:
* Cobalt S20G Turbocharger
* Cobalt S20G Turbo Oil Solution
* Cobalt Direct-Mount Turbo Manifold
* Cobalt Quick-Mount V-band Turbo Exhaust Housing and MaxFlow Downpipe System
* Cobalt Turbo Air Intake System
Cobalt Front-Mount Intercooler
* Cobalt Charge Air Piping System
* Cobalt Billet Blow-Off Valve System
* Cobalt StreetRace CNC Billet SheetMetal Intake Manifold
* Cobalt Turbo Fuel Injectors/Harness mod/PCM calibration
So in short yes, It includes everything you would need.
Last edited by car_guy_09; Jan 15, 2009 at 12:38 AM. Reason: Automerged Doublepost
Level V:
Level V:
Oh by the way you would also need a new clutch and some drive train mods.
The G-force sport's is what i run, And many others run KDW's as they are pretty much the best all around street tire your going to find that will last more than 5,000 miles.
The difference is, The KDW's are a softer tire so they grip better but also wear faster, And are a little noisy because of the tread pattern.
No problem,
And yes at some point you would want a clutch, Probably a spec stage 3, Linky and this is really all you would need for the drive train Linky
Last edited by car_guy_09; Jan 15, 2009 at 12:46 AM. Reason: Automerged Doublepost
