Hard To Find Exhaust Leak !!
I'm not having any luck tracking down a possible exhaust leak !! I can't seem to pin piont where it coming from. It's either the flex section or a cracked manifold. I Know that you guys can't say for sure over the internet. But, has anyone else ever had a cracked manifold at all ? My flex section with the cat in it ( The down pipe ) is only two years old. Not that that means anything. I just can't seem to find it. It almost sounds like air rushing threw a small pin hole.
Could it be some kind of boost leak ? Like the boost bleeding out the accuator ?
I'm so confused !!!
I'm so confused !!!
Have a friend stuff and hold a rag in the end of the exhaust and look and listen verry carefully where you suspect the leak to be, also feel with your hands for the leak as well but dont burn yourself. oh also lok for soot or carbon where you suspect the leak to be.
I had a flex start leaking.....the inner part of the flex broke loose and sounded like a leak.
It was under warranty and the dealer could not find a leak.
Eventually with the inards broken the flex started to weaken and then sprung a leak.
I have had 2 ZZP flex's break and I have had a cracked manifold. There isnt really a way to tell unless you go to and exhaust shop and have them pull out there modified stethoscope so they can pinpoint exactly where it is coming from
Thanks for the replys everyone. It deffinitly sounds like a hissing. That is i guess the best way i can describe it. I'm guess by the sounds of what most are saying it could very well be the inner part of my flex letting go !
it almost sounds like a turbo starting to spool and build boost.... Also, i just noticed that my boost guage isn't going up as far as it use to. Not by much !
i would definatly say flex and ur boost gauge isant reading as high because maby the temp is not leting it pull in as much air/ its leaking enough to make it have less pressure= less boost.
well i had an exhaust leak between the head and manifold and i removed the gasket and sprayed it with the copper gasket maker spray can and installed it after it dried up and BOOM no more leak...car is so quiet now i love it.
i also had another leak right at the downpipe junction and i did the same....copper gasket maker is the shiz naitz
It's funny you mention that. I have the car in the shop right now. And the mechanic just called and said he thinks the gasket between the down pipe and mid pipe is leaking. So he is gonna pull it apart, clean both ends up and put a new gasket in and see how that goes. He said the noise is not anywhere near the flex section. I hope he is right !
Its normally a very small slit that is hard to find... you almost have to bend the flex to see it.
Stupid Shop didnt get back to working on my car today !! They gave it back to me and told me to drop it off monday morning and they will finish it then. They do have a header for my car i can buy from them for $100. But it has no cat on it at all. Won't that trigger a cel ?
no way
i hope you meant DP
and it will most likely set a cel. but i woudnt know since i have rear o2 flashed out
MAn i got the same fkn issue seriously getting frustrated aswell and my shop sayed the same aswell i usualyl work on my own car but decide what the hell icant find this leak they said it was the flex pipe and after they changed it it same sht i drove around the block and the car started again just like a turbo spooling da mannoying as hell ! HE told me the flex was probly defected but another guy told me its thew flex pipe itslef i cant use the flex with the locks on the inside he told me to get the one that has the mesh inside and out but my tuner said go with the one i bought. So yeah nothing till monday aswell here . Iswear it gota be a gasket it has me going nuts i cant enjoy my jbp header ! LOL
