Header question
Header question
There are lots of header options out there. Vibrant, OTTP, ZZP, Badmab, GMPP and so on.
Would installing a header and/or a full exhaust require a tune, or is it safe enough to drive it on a stock tune.
Its fine on the stock tune, however you wont get the most out of those mods without a tune. Plus you may get a check engine light do to the downpipe if you go catless or even with a highflow cat.
Only time you would need to change the tune is if u did what i did. I had the TVS, meth, intake, tune...the whole works...then changed my exhaust. Tune needed to be adjusted cuz the fuel trim and afr were all over the place.
z28addiction
Sep 28, 2015 12:03 AM
